Auna HKMIC-CM 280 - inside a cheap USB desktop microphone.
rock soderstrom
Tour de France
Berlin
As you know, I have a soft spot for strange-looking microphones and am always on the lookout for suitable donor bodies for my own projects.
I was able to buy today's candidate for very little money on kleinanzeigen, let's see what we got for 5€.
1000031091.jpg1000031093.jpg1000031094.jpg1000031095.jpg1000031096.jpg1000031098.jpg1000031101.jpg1000031105.jpg1000031106.jpg1000031109.jpg
I am surprised to find an externally polarized capsule, the body is not bad, a bit small for a tube mic ;) but it will all fit in. The lettering is unfortunately partially lasered or etched into the chrome. I think I'll relic the mic a bit so that the chrome looks like it's from world war II. That will be exciting. :devilish: The housing openings that are not needed will be covered with a fancy nameplate. That's the plan. Stay tuned...(y)
View attachment 147822View attachment 147823View attachment 147825View attachment 147826View attachment 147827
View attachment 147828View attachment 147829View attachment 147830View attachment 147831View attachment 147832View attachment 147833View attachment 147834View attachment 147835View attachment 147836View attachment 147837
View attachment 147838View attachment 147839
I am surprised to find an externally polarized capsule, the body is not bad, a bit small for a tube mic ;) but it will all fit in. The lettering is unfortunately partially lasered or etched into the chrome. I think I'll relic the mic a bit so that the chrome looks like it's from world war II. That will be exciting. The housing openings that are not needed will be covered with a fancy nameplate. That's the plan. Stay tuned...(y)
You got an interesting toy for 5 euros 😃
Is the mic's body metal?
Yep, full metal. Quite stabil and robust body.
And the mixer - lovely prize.
The pots alone are worth more than 20 euro 😉
The price is killer - I use these Mackie mini mixers a lot. I like the old design better visually, I'm curious to see if there are any other differences to the VLZ3 (which I also have).
That's why I love buying "broken" things.
Very often the cause is banal 😉
You're right! Most of them had minor defects.
Some weren't even defective, they had the plugs connected wrong
Or they used faulty cables.
+1 You're both right, most of the time it really is small things. (y) Sometimes I'm really disappointed because the errors are so trivial but I'm in repair hero mode.😅
my best guess would be :
pcb as big as the mixer itself .
pots mounted to that pcb on which all components are smd of course .
that means :
--take of all knobs
--unscrew every pot screw underneath them ( don't loose any of those washers )
--unscrew the bottom plate
--remove pcb without damaging anything
--replace master pot
--now the whole thing from bottom to top .
can you do it in 2 hours ?
My guess is that the pot itself is fine, but it has a cracked solder connection to the board.
My lucky streak continues, you were right.(y)
Easy repair by re-soldering without having to order a new pot and without removing the bottom motherboard, which really wouldn't be that much fun since some genius replaced the screws for mounting the PCB with soldered-in(!) posts. Congratulations for this very smart solution Mackie:sick:, very service friendly if you need to replace a pot. That wasn't the case with the older models, unbelievable!
Total time for the repair (and cleaning) was 12 minutes, the pot caps are not yet back on because I'm going to wash them, as they are a bit yellowed, bleach detergent works well.
By the way, stubborn poti caps can be removed very easily with finger picks.
here the broken soldering point, maybe it was never soldered right?
this one of the ~10 soldered PCB holder👎
