Avalon VT 737 sp
Ok the 7372 card is the I/O card. It is used in conjunction with the tubes.
It's been a long time since I have seen schematics for the main board, there are a lot of parallel processes going on which is why the unit is practically noise free. with a ridiculously low noise floor.
I also recapped the 7374 just in case, would u recommend to recap the last card too?
Eureka, my avalon works again, line and mic, rumble noise when pressing in phase also disappeard
issue lied within in the 7372, must been one of the caps on the left
7374 is the compressor card.
7373 is the EQ card. It shouldn't cause any issues to recap the eq card at this time with the usual replacement 10UF and 100UF. About the only issue I see here is if you accidentally plug the card back in but miss a pin like you had previously done on another card. The 7373 card has two headers. While they are offset so that you can't so the card will only fit one way it's still possible to be a pin off. So do exercise caution when you do.
Hahaha thanks, yea i learned from my mistake and now always look to lineup the screwholes, okiladokili, i will recapd the 73 in the near future, i already screwed everything in place and hope i dont have to open it up again
Avalons commitment to excellence and striving for perfection, the tolerance on the mechanicals is super tight. In my shop time there, we had single post it note style paper that we would slip under the pots before putting on the knobs. It ensured the knobs wouldn't rub the faceplate but also shows the tight tolerances I mentioned previously. again great job on accomplishing getting it back to working. it feels good. ;)
Congratulations! Aging caps on the 7372 is a common source of problems.
I'm surprised these changes would affect the phase button, as all that does is connect a 12V DC signal to relay K2, causing it to swap the hot & cold pins of the Line Out XLR jack. But glad the problem is gone and crossing fingers that it stays that way. 🤞
Thanks everyone for their patience and support 😇
maybe it was because of the shorted r19?
Just recapped the 7372, think i did a great job being my frist time doing this
    488.5 KB
    435.8 KB
except that is the 7373 card, aka eq card. But yeah not bad at all. :)
haha yea, replaced all the caps on all 3 cards tho, had to get to soilder iron to 500 degrees celsius to be able to desolder the through hole connections, what a pain, the desoldervacuumpump was a blessing, an absolute bang for the buck
but i managed to rip of a pad before i had the pump, what a bummer, cleaned up the mess and fixed it, ofc i also burned alittle bit of pcb, but nothing tragic, doenst look pretty but hey
just recorded the first song, ahhh it sounds so clean
this project really sparked my interest of doing more stuff like, maybe like a diy equipment project, i also have a notebook that died on, but thats a whole different kind of skill ceiling
i think what can be concluded is if voltages check out, no visible damage and resistors look fine, best shot would be just recapping the i/o card
had this problem since i got this unit couple years ago worked fine the first couple months, after refitting the tubes in different sockets the problem went away for couple months, but the next time it didnt helped.
i am really interested in knowing whats causing this, like how is it behaving like that when a capictator died, but it sporadicaly starts to function again
maybe somone has an thesis
Well the cap might not be totally dead. It may be out of tolorance from age.
Like it’s not holding a full charge like it used to.
Wow ripped a pad off, been there. 🤫 keep that a secret. Or don’t. But we have all done it and fixed it.
Years ago I looked at a desk where the aux masters had catastrophic failure and all traces were gone. I made new traces out of wire and held them fine with nail polish. It still works to this day. What caused the failure in the first place who knows. But I did get it fixed.
