Kingston
My3gger said:What values have input filters in ver.4 at 20mA? Have you also tried 1meg pot at 300v in ver.4?
That 1 meg works for all variations and voltages, no need to change anything there. I've tested this at 250VDC now (input about 280VDC) 30mA too. I'm sure that 4.7uF filter for zener reference is enough for all cases too. When testing I've had input ripple in the range of 0.5-1VAC. That will be gone completely. Output is very clean indeed.
300VDC should work fine as well. See PRR's post how to calculate the watts and the input resistor for the zener, that's the only thing you need to change. Pay attention to MOSFET cooling when passing a lot of watts.
My3gger said:Btw, Fearn uses simple zener shunt regulator and it seems ok there.
They work, but this solution easily scales to much more than just 100mA while I wouldn't trust a zener there. This has far less noise too.
