Lassoharp and I ran tests on a lot of different transformers in a BA-6 test bed he built. We powered it with several bench supplies so as to dial in voltages precisely, and took measurements with no gain reduction, and up to 11dB gain reduction, pink noise as source. We used a Gates SA-39 input transformer for some tests, and a Gates Dual Limiter input for others. We looked at a bunch of different outputs, and noted the feedback seems to make the outputs look mostly the same on the bottom end, though top end differences did exist. We also looked at a multitude of possible interstage transformers. We did not find need to tweak GR balance to any great extent, perhaps we got lucky with our selection of GR tubes.
The #1 question regarding the quality of the Sowter interstage transformer seems to have been answered satisfactorily; it seems to perform fine.
Both plots show an original RCA output transformer.
For all examples, gain reduction tilts the response toward the treble end.
This is an SA-39 input, Sowter interstage, and RCA output, with 0 and -11 GR matched at 1K for comparison.
This is a Gates Dual Limiter input and interstage with same RCA output, 0 and -11 GR matched at 1K for comparison, SA-39/Sowter/RCA/no GR left for comparison. I show this one because 1) Dual Limiter is very close to the BA-6 gain reduction stage and 2) the Dual Limiter input transformer has greater top end extension than the older SA-39 input.
UTC A-18 works OK when run backwards, but the step down ratio means you get less limiting and it automatically lowers the max ratio before input overload. We tested an RCA 86 limiter interstage and it also worked fine, same step down ratio issue though. You really want a 1:1 here or limiting action will not be correct.
In general all the oddball interstages worked fine so long as they had passed initial assessment for inductance. Shopping for such would be a crapshoot, with so many specs unknown until in hand and measured.
