vinyvamos
Has anyone yet tried the Lundahl LL1635 in a BA-6A build? It would be great to get proof of an alternative to the Sowter
Why on earth would this even remotely be a consideration for RCA in the 1940s? From the get-go the move was toward smaller systems. The pressure was on making everything more compact. (and presumably less costly). Shielding made the cans bigger in general and no modern trafo maker that I have seen offers the level of shielding that was standard back then.
Read it again. We never had an original.OK point taken. So are we talking half an inch of shielding here? I think the tests that yourself and Doug did were extremely helpful to the cause here, but damn damn I wish you had tested the L & DC-R of the original BA6A interstage
Bumping an old thread but any update on the availability of these so tests could be performed?I have done for experiment new version of the interstage transformer BA-6A ,
ratio 1 : 1, on a core 375 UI ( right side ). My previous version
were 31 UI , 8X15mm stack , ratio 2 : 1
Turns ratio: 1 :1
Z ratio : 30k : 30k
Coil structure : bifilar
LAM : 375 UI , Stack : 10 X 18 mm
This thing is wound :
2 coils - each coil has >
pri - 2770t #42 ( 0.063 mm) enamelled wire + silk covered (blue) , DCR 730 Ohm
sec - 2770t #44 ( 0.05 mm) , DCR 1180 Ohm
pri & sec BIFILAR wound
Total :
pri - 2770t + 2770t = 5540t , DCR 1460 Ohm , 240 Hy PP
sec - 2770t + 2770t = 5540t , DCR 2360 Ohm , 240 Hy
L mesured at 100 Hz .
Set of winding wires :
Don't expect any opinions anytime soon. I'm away for the rest of the month & have work backed when I return.Hi Rob,
Nice, I've been thinking about that one, too but am only slowly gathering parts now as I'm unfortunately in the middle of a move...
I've seen a lot of your posts over the years, I look forward to your review!
Chris
P.S. Not to hijack this thread but what're your thoughts on the Hammond 812 for the control amp input for a Fairchild 6x0 build? I asked in that thread but got no input (bad pun...). If you have any thoughts, you can PM to keep this thread clean/on-topic.
Got a bit further with this recently (unfortunately due to lack of paid work).No worries Rob. I've got quite a bit of things outside of DIY/audio going on myself, probably until end of year...
For reference the Hammond 835 has d.c resistances of
Pri 1 866R
Pri 2 1050R
Sec 1 930R
Sec 2 956R
Not at a stage to run audio yet as I'm waiting for some parts.
I'm not looking to confirm or deny anything. I didn't see any specific info about this transformer from you or Doug which is why I added it. I don't have an inductance meter, therefore can't add any figures in that respect. Fazeka just asked for info. Unfortunately since I bought this transformer new from Mouser earlier this year as a special order they have now discontinued it from their catalogue, so I'm not sure if Hammond even still manufacture it.It will work just fine. Been there, done that. Not sure what you are looking to confirm or deny. That info was present for the tests Doug and I ran some years ago that is documented in the group. But, sometimes there's no need to mention things directly, and good reasons for doing so.
"But, sometimes there's no need to mention things directly, and good reasons for doing so." It's there, to be inferred from the commentary. Hammond still manufactures it, so it won't be unobtanium. Hawk has themI'm not looking to confirm or deny anything. I didn't see any specific info about this transformer from you or Doug which is why I added it. I don't have an inductance meter, therefore can't add any figures in that respect. Fazeka just asked for info. Unfortunately since I bought this transformer new from Mouser earlier this year as a special order they have now discontinued it from their catalogue, so I'm not sure if Hammond even still manufacture it.
