Bal/unbal fx box connection advice
dirty1_1garry
Moscow
HI folks!
Want to build a guitar pedal type compressor/fx box so it can get both balanced line level signal and unbalanced guitar level signal on same TRS jack.
One more aspect is 9Vdc wall adapter power supply typical for guitar pedals.
For supply ICs I’m planning to use Traco DC converter which create +15Vdc and -15Vdc from 9Vdc with separated ground.
For bal line in/out - That 1246/1646 drivers
For unbal in/out - simple opamp buffers
For switching between balanced and unbalanced inputs/outputs planning to use group of relays.
schematic sketch attached.
question is:
how it’s better to organise Sleeve pin connection in an aspect of that balanced line Sleeve pin is  typically connected with a chassis, but in unbal connection its typically connected with signal ground (especially that signal ground is separated by DC conversed from 9Vdc supply ground)
Not quite the question you ask but from a quick glance you don't need a separate opamp to provide the unbalanced output.
The THAT driver can be used single ended simply by grounding one output. A mono TS jack (ie a 'guitar jack plug' will do this automatically.
And any decent balanced in device will do the same at the imput.
Yes indeed.
But I guess that the OP wants a high Impedance - into the MegOhms - available for the guitar input.
On that point the input buffer shown won't work as it is missing a bias resistor from the non-inv terminal to 0V for DC bias.
Move the 2M2 resistor to the other side of the cap or if you are using the 2M2 for input capacitor discharge to minimise 'pops' then fit another resistor after the capacitor.
But I think the OPs original question was about what to do with the Screen / 0V connections on the TRS / TS jack.
Back to the old 'Pin1' issues / isolated (or not) jack sockets / ground loop breaking circuits etc.
Complicated by the fact that using a TS jack into a TRS shorts out the RS connection.
As Newmarket says: do not omit the grid-leak.
Buffer BOTH inputs to MegOhm. Balanced sources will not mind. The extra 11 cents is less than the cost of the switching.
Let the output of the '1646 do what it was designed to do. It will adjust for one side grounded.
No switching needed.
Newmarket said:
Yes indeed.
as I understand, DC bias should be if opamp os supplied by single rail supply, but not in situation when opamp is supplied via bipolar supply. Am I wrong?)
useful recommendation
that's the main question, yes) attempts to get rid of ground loops
smart and simple ideas as usual , PRR! 8)
What if we will add MegOhms for 1246 inputs directly? Or it's better to buffer 1246 additionally?
peterc said:
Given that most guitar pedals are for low level signals, you might want to consider a pot after the input stage.
Or even a pad before the input stage.
Peter
yes, of course! but that's the simplest question in comparison with the questions that I encountered and try to solve here  :)
I had assumed you did your homework.
Look at the THAT1246 datasheet and figure what the input impedance is.
simple reason, yes!))
input impedance of 1246 is 24K, thats the reason of additional buffer with megaohm resistors. Go it, thanks for a tips!
Yes.
Inputs must have a source of dc current for the bias current requirement.
In a single supply circuit the voltage used is usually half the supply voltage to allow for ac signal around that. In a dual supply +/- system it's simply biased to 0V - which is again half the supply voltage.
Difficult to be definitive here as your box is trying to allow for different uses.
So...in an ideal world balanced connections should be able to have all screens intact allowing bonding of S connection to (metal) chassis and all is good.
BUT it doesn't always work out like that - pin 1 / Screen gets mixed up with signal ground and we get hum and buzz and the rest.
With unbalanced input  you are inevitably mixing the Screen function with the Signal 0V.
There's loads of stuff on this on the web - google 'Pin 1 problem' 'Neil Muncy'
But you want to know what to do now  :D
Okay - google 'Bo Hansen DI' and look at the scheme there.
The output connector screen connection (XLR pin 1 = S on TRS) is bonded directly to chassis (and nowhere else).
Input connector S connection is isolated (eg plastic body TRS jack) from chassis but connects to chassis through a parallel resistor / capacitor network. Some largeish diodes there too but may not be needed in your application.
You could put a switch in to bypass this if you wanted to although it's probably not necessary.
Input screen connection is compromised but it does work well.
There is an argument to be had about where the ground loop break should be in the chain but practically this seems to 'do the job'.
Others may have different approaches...
one more idea that I had in my mind before posting these post was - in unbal connection connect R and S pins to signal ground and in bal connection connect S pin to chassic and (may be) with signal ground through resistor/capacitor as Bo Hansen sch shown.
May be I just need some sort of ground lift switch that will connect Spin differently and allow to minimise any hum troubles.
Any way I should experiment a little bit to find the best way in exact situation.
Thanks for nice tips!
