Thanks - this clears up why this ohm/watt swap happens, I was curious why we seem to see it quite often
50kΩ turn on resistance would still be alarmingly wrong though, as opposed to possibly mΩ.
Re "turn on resistance" and value :
Now you mention that - yes it's all wrong
"The MM74C922 and MM74C923 CMOS key encoders provide all the necessary logic to fully encode an array of SPST switches. The keyboard scan can be implemented by either an external clock or external capacitor. These encoders also have on-chip pull-up devices which permit switches with up to 50 kΩ on resistance to be used."
The explanation seems quite correct to me. Some switches, especially on soft keyboards, have significant resistance (I once measured more than 1kohm) in the on state.
On the top left corner of the first page it states that it is Beijing company. The data sheet is likely to be written by a non-native English speaking person. So, they used the wrong terminology.
That text actually means the pull-up resistor value. Switch-On/Turn-On resistance is not the same thing.
That particular error is a combination of case and font error. Uppercase omega is Ω, but lowercase omega is ω. If the typeface you are using does not have Greek letters sometimes ω gets converted to W when you try to change to upper case. Or possibly an editor without the technical background to catch it mistakes ω for w, and sees that kw is not an accepted abbreviation for anything, but kW is, so "helpfully" changes kω to kW instead of kΩ.
And did the OP ever say why he wanted a balanced output from a guitar pedal??Getting back to the OP's orifginal question, he is building guitar pedal type circuits operated from a 9V supply. I would suggest simple impedance balancing is all that is required.
Thanks Ian for thinking about my original question.Getting back to the OP's orifginal question, he is building guitar pedal type circuits operated from a 9V supply. I would suggest simple impedance balancing is all that is required.
I think balanced has a better signal to noise ratio (at least for studio use)And did the OP ever say why he wanted a balanced output from a guitar pedal??
Most balanced-input devices can accept balanced or unbalanced sources.
Might this be a solution in search of a problem?
Thank you for putting us back on rails.Getting back to the OP's orifginal question, he is building guitar pedal type circuits operated from a 9V supply. I would suggest simple impedance balancing is all that is required.
