k brown
All depends on which transformers you compare them to. The chips are certainly superior sounding to most small, inexpensive transformers.
Thanks. New name to myself unlike the other three there.Back in the German golden age of audio there was a weird conglomerate of Neuman, Telefunken, Siemens and among them, WSW
Why didn't they show the CMR vs. Rsource diagram?
It's of technical interest but not particularly useful imo. It has been stated that a low impedance (low as in opamp output Z etc). So why would anyone choose to drive it from a significant source impedance?
Unfortunately, THAT is great for making chips, not that great for making data sheets. I've noticed an error in one of their line receivers data sheets, they provide a circuit and state a wrong figure for the common mode input impedance using the resistor values they suggest in the diagram.As I said before, the absence of any diagrams in the THAT1646 datasheet doesn’t look professional to me.
A diagram of the internals of the chip would not be terribly helpful.As I said before, the absence of any diagrams in the THAT1646 datasheet doesn’t look professional to me.
It is true. There is nothing more frustrating than finding a value in a data sheet or book, which doesn't agree with your calculations and you loose a lot of time re-working your calculations and thinking that you must be wrong because the book or the data sheet can't possibly be wrong....tbf all chip makers - analogue / digital / micros etc are subject to errors and corrections
They can throw you though. Esp when it's eg a microcontroller with complex / optional functionality.
because you might want to drive it from a fader for example where the source impedance might vary from zero to about 2K5 for example.It's of technical interest but not particularly useful imo. It has been stated that a low impedance (low as in opamp output Z etc). So why would anyone choose to drive it from a significant source impedance ? x
I agree. I have just been working on a design that uses that very device. I read the app notes to configure the chip correctly but nowhere do I recall such a warning. It might be somewhere in the datasheet but something that important really ought to be highlighted.Yes. But imo what you need to know is that you shouldn't do that. You need to buffer the wiper signal.
If you're not going to do that then there seems little point in using those parts with their precision trimmed values.
They could have built in active buffers, its only silicon and money . Anticipating fader/volume control use, they would want to have differential inputs to insure good pot kill. Looks like they decided to keep it simple.
I still haven't used one and am now unlikely to, since I only melt solder to repair stuff these days.
I don't want to drive this veer too far off into the weeds but audio paths that already have differential outputs (like many mic preamp topologies). A volume control could bridge between the two hots but that would require exceptional CMRR to deliver very good pot kill.The THAT1606 has differential inputs. And a simpler CM implementation using one small value cap'.
