cariocaman85
- Joined
- Sep 24, 2011
- Messages
- 115
Thanks for your reply, I sent you a PM as wellMany consoles route the direct out to it's channel's # MTR bus out when the DIR button is pressed.
It's been a long time since I used a 8232 but it would be worthwhile to confirm if that is the way it works. The patch point you refer to may simply be a way to access the signal before the routing matrix, if you have a few days to spend pouring over the (terrible) manual or 60 seconds to try it on the console you can confirm.
If you have output cards that are set up for transformers I have a single VT24499 that needs a good home... you are welcome to it. Maybe between all of us you can fill it out!
If you want to add separate D/O it may be much simpler to use another power supply to feed them (especially if you use class A outs as the draw is greater). Power One modules are cheap on Evilbay these days.
I just did this exact thing on an incredibly expensive console that has almost no routing features (current trend, unfortunately), by tapping the post fader buffers and sending them to class A drivers (2nd half 283) then the transformers.
Any way you do it you need a driver to feed an output transformer.
I have read the 3 books of the manual already l, but I will go through it again. It's strange that there is no schematic of the direct output... But yes I tested and they come after the multitrack send and before the matrix.
Thanks a lot to everyone for all this help!
