petermontg said:You can place the last resistor on the chain into the short positions save having them hanging off the rotary.
No need - theres an extra lug on the switches Im using
Gustav
druu said:Single pole is all that's required. The extra pole would be there to add rigidity if mounted to the board.
druu said:No, that EQ below the BP is built using Igor's GML/Massenburg 'MEP250' boards with MS/Bypass, before the DR-MQ5 copies came out.![]()
yourdudeness said:Hello, any recomendations for L1?
You probably refer to C21/C22 (100uF/25V), not C26/C27 (100nF caps). No problem, as long as caps voltage rating is higher than voltage across these caps (>18V in front of 7812 and >12V after 7812). Higher voltage rated caps most often come with increased outer dimensions.petermontg said:In C26/27 I have 2 100V Caps where should be 25V. Would this be causing my problem, I am not sure it is.
missing value for your V reading, probably something in range from nada up to +12VDC.I am reading V for the relay afterwards.
Maybe double check polarity of C19, C20, C21, C22, orientation of diodes D1, D2, D3, D4 and transistors are BC182 for real (not different pinout BC182L).I unplug PSU to double check still checks out fine when plug it back in voltage slowly rise/increases when checked what the PSU is doing when plugged to boards and no voltages across previous checks
This has lead me to think that there is something amiss in C19/20/21/22.
Anybody want to add some insight to get my brain thinking in the right direction. I could have hit the nail on the head already?
Not needed (unless your BC182Bs are broken). Problem will be in a different spot then. (Relais ?, additional LEDs with maybe missing/wrong current limiting resistors ?, insufficient current delivery from preceding +18VDC stage ?, ...)petermontg said:I will try with the BC182
Continuity test AKA beeper mode ? Only maybe useful for sorting unlabled multicore wires or hooking up a caravan, but not much use in electronics. Use your multimeters ohm setting in order to get a meaningful number. A short will give a zero or close to zero ohm readout (pcb traces and/or your measuring leads have a resistance as well). You never said what psu you are using, whats the data of the mains transformer in front or whatever circuit variations or add ons you have implemented.petermontg said:I have Continuity across a couple of the PF and NF caps in the same places on both boards...
Maybe only your assumption is wrong that the 10-pin connectors are populated with same orientation, IE pin1 of CON1 and CON2 are both the leftmost pin ...druu said:I'm still convinced the schem pinout is wrong for the PSU input wires..
