druu
Ok I stand corrected.
I must have had a brain fart during that stage and switched my wire colours for some reason.
frazzman said:Looking good here so far... Wired up one band and boost/cut is working.
A few observations when analysing using RMAA:
- max boost seemed to be a bit under 4db at max position - using 21 step rotary, I was expecting 5db?
- on the freq plot the Q control looks pretty much the same at q=1 and q=3. Is there supposed to much difference here? They are both broad Q's I guess but I can't hear/see the difference. - I'm using 12 pos alpha rotaries for Q control
frazzman said:The only thing I can think that may have caused a problem is that for the Q Switches - I used the Q calculations from one of Harpo's earlier spreadsheets. This contained calcs for a 12x1 rotary switch... (see attached)
I then used one of the the later revision spreadsheets and followed the calcs specified for 24pos freqs and 21pos gain switches.
you probably only missed to jumper two circuit nodes, as the quoted headline of the calcsheet snipplet already says '...and shorting out opamps non-inverting input with pin1 of the 'Q'-pot from Barrys schematic...'.frazzman said:... with tests just limited to MF1 band - the plots are identical with both Q=1 and Q=3, changing the Q position has no affect. I can hear clicks in the audio as I toggle through the switch positions, FWIW.
I followed all the resistor shorts positions and omissions as per Harpo's spreadsheet(s) - (at least I think I did...)
Harpo said:you probably only missed to jumper two circuit nodes, as the quoted headline of the calcsheet snipplet already says '...and shorting out opamps non-inverting input with pin1 of the 'Q'-pot from Barrys schematic...'.frazzman said:... with tests just limited to MF1 band - the plots are identical with both Q=1 and Q=3, changing the Q position has no affect. I can hear clicks in the audio as I toggle through the switch positions, FWIW.
Harpo said:FI Q setting mono pot P10. Jumper the right and center hole on pcb and connect switch pole and switch position 1 to this jumper. Last switch position resistor goes to the left side hole. Jumper R110 or fit this last switch position resistor here instead so it doesn't hang lose on your Q switch.
Same procedure for the other Q setting switch asemblies.
kml23956 said:Who can explain this in simple terms? I need to know what they are and how they are wired? Are they 2 pole 24 , 4 pole 24, 2 pole 23...etc.
petermontg said:Whats in R62?
