The tube trap is based on resonance of a closed (at one end) or open tube - it’s basically like a big Helmholtz absorber with a large mouth, not a reduced sized tuned port. The air inside the tube resonates at whatever frequency the length of the tube and the diameter of the tube dictate, the absorptive material provides the impedance to free resonance within the tube. The idea is to get the resonant frequency of the side to side here so a full side to side 3M open tube will be 1/2 wavelength ie. wavelength of 6M and a fundamental of 57.28Hz, The resonant frequency across the 3M wide room is 114.56Hz so the idea is to have a tube that absorbs the pressure from the corners and damps it within the tube. A floor tube trap closed one end 1.2M x 225mm will absorb down to roll off at 110Hz (absorption coefficient less than 1), a 3M 200mm pipe open both ends will roll off at around 100Hz. A 1.5M 200mm pipe closed one end will do the same so one open to each corner works best. The larger the diameter, the greater the efficiency, the longer the trap, the lower the frequency of absorption. Also as these absorb above and below resonance they cover the harmonics.
But the idea is to stay within practical bounds when limited by what space is available.
It’s sort of equivalent to packing the corners with heavy absorbing material. Seems to work. 1/2 room height (1.2M or 4ft) closed end vertical bass traps have been around a long time which seem aimed at ceiling reflections, other lengths target width and length. I just found a cheap way to make them and not pay silly money by using second hand water pipe, cardboard concrete form tube which is cheapest or newsprint roll cores.
