Behringer ADA-8000 owners: PLEASE READ!!!
It may not be a ground loop, it may be that the current draw of multiple units drag down the secondary voltage enough that the regulators drop out of regulation, which will indeed turn them into 120Hz (100Hz) hum generators.
A voltmeter across pins 1-3 of the positive regulators (or 2-3 of the negative ones) will tell you if this is happening: these regulators need 2-3V worst case across them minimum in order to stay in regulation.
The pins on 15v regulators gives approximately 9V when all three units plugged, 10V when only one
The pins on 5v regulators gives 2V when all three units plugged, 2.7V when only one.
I have oscilloscope, can I check something with that?
Edit:
I have played with an oscilloscope.
Don't know what I am doing but still...
The voltage on 15V regulators is flat but on 5V regulator has a small oscillation when i plug all three units
The input stage of 074 opamps output pins doesn't do anything
Ad da converters, i think. And optical adat in an out
But now i see that there is only 2.5 volts on that picture. I will check
Yes, i have checked, it is 5V. But there is a ripple
So the next step is to check the input to the 5V regulator. Nothing obviously wrong with 12V (at least no noise, so assuming that is actually 12V, since the trace isn't scaled to have the reference point on screen to verify).
This is when unit is pluged in
This is when probe is on gnd and rectifier diode
This is when all three units
Sorry, I think I may have misinterpreted. When you say the probe is on the rectifier diode, do you mean the junction of D10 and C1, so effectively the input to the 7805?
I find your terms of where you probe vague, it would be helpful to point out a specific node on the circuit you are probing to be less ambiguous.
But that waveform described as probe on ground and diode looks like the output of a diode with no bulk capacitance. With a 1000uF capacitor it should be mostly DC with just a slight ripple (unless there is a huge current draw). The scope was a little hard to read, but I think it should be right around 10V DC and dropping down a bit based on current draw. Should definitely be enough to keep a 7805 in regulation.
What is the current draw on the 5V analog supplies?
The power supply circuitry in each ADA8000 is all stock, all you did is take out the original transformer, and put two transformers in an external box which has a set of wires to the existing power supply circuit in each of three ADA8000 units?
Yes, the probe is there. Sorry. I am not native english speaker so i write short as possible.
And yes to that
I don't know.
And i noticed when i hold 5v wire on transformer with aligator probe when unit is not plugged in, i hear slight buzzing on my studio monitors.
Other probe is not connected
I am sorry, this is new readings
Input regulator
Output regulator
I have uploaded a little video
When the usb of the soundcard is connected (rme digiface) the ripple jumps
When disconnected ripple disappeared for few seconds and then gradually turns on
When i turn the laptop off it is the same like i disconnect usb
Rme is usb powered
Laptop is on the battery, nothing is plugged in in it except for rme, only this power supply is plugged in in wall outlet and oscilloscope
I even turn the lights off, to check
  • 1000011040.mp4
    30.2 MB
