living sounds
Don't use poly caps for PSU decoupling, they are inductive and thus useless at higher frequencies (where oscillation can easily occur). Ceramics are what you want for this application.
No idea where your decoupling caps go but in any analogue circuit, the important caps are electrolytics.usekgb said:The Wavefront app note suggested using poly's or high quality ceramics, so I used the poly's that I had on hand. I'll see if I have any ceramics around. If not, I'll pick some up on Tuesday.
usekgb said:Anti-aliasing filter. Got it. No easy fix for that one, as it would be in the AD converter.
usekgb said:I wonder if adding a pre-filter at 48 kHz before the converter would help. Do you think this could help with the aliasing problem?
Yes.usekgb said:I added 10uF caps to the supply pins of the input OPA, but didn't have time to add them to the output. Are you suggesting adding a 'lectro to the V+ of the converter chip as well? As for grounds, the ADA8000 appears to have a big ass ground plane instead of separate grounds for digital and analog. The caps I added to the supply pins of the OPA are connected to a nearby analog ground.
You've done about as much as you can by swapping to OPA4134. Among the uber OPAs, its the one which is least fussy. That's why it often gives better results in 'real life' than more highly spec'd stuff.Anyone have any thoughts on just ripping out the TL074's, and replacing them with differential OPA's like the OPA1632? After reading the app notes on the PCM4222, it seems like it might be a good solution to clean up and simplify the analog front end. In the end, I was planning on bypassing the mic pre's anyway. Opinions?
usekgb said:I'm still interested in the OPA1632 idea though. Maybe I'll build up a small input PCB and give it a try.
usekgb said:Fair enough. What I have already done is quite an improvement. The only reason I wanted to try the opa1632 is because it avoids the whole invert and invert again that is happening now. And, I've never used one before. 8) I use the opax134 all the time, and it always does a great job.
G-Sun said:I did a comperison with my RME hdsp the other day
http://geir-music.blogspot.no/2014/04/converter-test-behringer-ada8000-and.html
My practical conclusion is: I can't really hear the difference between the two,
so I'll leave mine unmodded and focus on making music![]()
