LTSpice sim says 27Hz and 3k. Looks like there's something wrong with the Japanese abacus.Gertius said:But as far as I can see it doesn´t match up with the schematics.
I enter the C´s with 150n and 68n and the R´s in one case with 100909 Ohm (result fc = 15.6 Hz) and in the other case with 909 Ohm (result fc = 1733.6 Hz). In my mind the result should say 30Hz and 3000Hz. Can anyone please tell me what I´m doing wrong?
Look at the 2nd schemo (Harrison): the opamp runs with a gain of about 3dB. that gives the correct Q for te filter. They had to compensate at the input; this inverter stage runs with about -3dB gain (3db attenuation).Gertius said:Hi guys,
haven´t checked back here for a while...
Interesting findings, emrr and abbey road.
Does that make the initial Behringer 2nd order filter an inferior design? Is it worth modding that to get closer to Butterworth response?
Would you care to post the filter response comparison from the Butterworth to the Intelligate, emrr?
It seems, the excerpt from the SSL schematic that I posted on page 1 of this thread uses 3x47K pots and at least 2x220nF caps.
Of course, it is different in that there is another opamp involved. Would be interesting to see that filter response in comparison, too...
Cheers!
Christian
Yes. The resistor values for the voltage divider must be low enough to provide a low source impedance to the filter even when the frequency pot is at max, and high enough not to overload the preceding stage.Gertius said:As far as I understand, in the Autoquad, the Opamp stage following the HPF is configured as a unity gain buffer (see schemo under Behringer in files section).
Is it as simple as changing the config to a non-inverting amp with amplification around 3dB and then adding a passive voltage divider at the input with -3dB to get closer to Butterworth response?
For a 3rd-order Butterworth you need to increase the gain to a little over 6dB. The optimization of the single-stage 3rd order Sallen & Key is quite difficult to solve mathematically. Using a simulator is almost mandatory.Gertius said:I sketched out the mod (based upon the 3rd order mod from page one of this thread), just to be sure.
Does this look right to you?
As it is, it presents a load of less than 500r to the output of the 1st opamp; it is too low. Now since you need a different attenuation (2.2) you need to change the values; unfortunately a 6dB pad is the worst case in that respect, presenting the lowest input impedance and the highest output impedance. I think you'll have to compromise, by using a somewhat higher resistance like 1.2k and 1k, which will present about 500r impedance to the filter ( the upper frequency range will be reduced somewhat and the slope less steep), or you may move the attenuator either between the HP and the LP section or at the output of the LP section.Does a resistor value in the "hundreds" look good for a start (like in the sketch)?The resistor values for the voltage divider must be low enough to provide a low source impedance to the filter even when the frequency pot is at max, and high enough not to overload the preceding stage.
I recommend you do that anyway.Can I just experiment with that and will hear/measure distortion when it´s not quite right yet?
No.Or can I break something here?
It is somewhat easier, because you don't need gain, but you need to increase the Q by increasing C13 to 30n, decreasing C12 to 2.5nF and making the added cap 10n.Oh, and one last question, can I mod the second order filter in the same way, for experimentation purposes?
I´d like to prepare one 2nd and one 3rd order Butterworth to compare...
Ok, I´ll rethink it then more into the directon of around 6dB gain and attenuation.For a 3rd-order Butterworth you need to increase the gain to a little over 6dB. The optimization of the single-stage 3rd order Sallen & Key is quite difficult to solve mathematically. Using a simulator is almost mandatory.
I get acceptable results with a gain of 2.2 and the first cap at about 60-70 nF.
Hm, could it be that there is a misunderstanding here? What I meant to ask was to modify the knee of an unmodded 2nd order HPF (as opposed to the 3rd order one that I attached the diagram of) to get closer to Butterworth response. C12+C13 seems to be in the LPF part of the circuit.It is somewhat easier, because you don't need gain, but you need to increase the Q by increasing C13 to 30n, decreasing C12 to 2.5nF and making the added cap 10n.
Gertius said:The Japanese site posted before seems a little funky, and the scale of the diagrams isn´t really too great.
LTSpice.Gertius said:Do you have any tips for a good simulator?
I agree; I've noted that the frequency box does not understand k or M - one has to type 20 000 for 20kHz. failure to do this results in an error message in japanese characters. But the worst is that the calculator does not cater for S&K structure with gain, only unity-gain.The Japanese site posted before seems a little funky, and the scale of the diagrams isn´t really too great.
YesAh ok, so the caps need to be changed as well?
Definitely not enough.I thought changing caps was mostly for the LPF? For modding the HPF knee I was planning equal value caps and pots, and just changing the opamp gain+attenuator... did I get that wrong, is that maybe not enough?
I would recommend you put it after the two filters; you may have to adjust the values in order to compensate the loading, but it would make the attenuation frequency-independant.I think I´ll start by moving the attenuator then. Maybe then the values are less critical? Should I still start with 1k and 1.2k?
Yes, some misunderstanding.Hm, could it be that there is a misunderstanding here?It is somewhat easier, because you don't need gain, but you need to increase the Q by increasing C13 to 30n, decreasing C12 to 2.5nF and making the added cap 10n.
OK, so you want a 2nd-order S&K HPF with equal value resistors. then you have to make the gain about 4 db.What I meant to ask was to modify the knee of an unmodded 2nd order HPF (as opposed to the 3rd order one that I attached the diagram of) to get closer to Butterworth response. C12+C13 seems to be in the LPF part of the circuit.
