Behringer Autoquad - modding HP filter slope
Ok, thanks again for the help!
I downloaded LTSpice, it looks awesome (and it´s free)! Can´t believe I hadn´t heard of it sooner!!
...the response has been dead on with the calculator result.  It gives more data that any other place I've found online.
Ok, I´ll give it another try as well. One thing that bothered me was the tiny rendering of the frequency response, I didn´t get comfortable with that.
But maybe LTSpice can help with that aspect.
Btw, abbey, entering "k" and "n" worked for me. Maybe you left a space? I entered for example 101k.
Ok, now I´m positive that I can figure out the right component values for the mod.
With both the Japanese Site and LTSpice I should be able to manage.
I´ll report back when I have news about my progress.
Here's a quick comparison of unity gain Sallen-Key filters against the Intelligate filter, to show the slope/shape difference.  Intelligate is red.    The panel markings for frequency on the Intelligate are a joke, and not to be trusted.
    69 KB
It works for the component values, but not for frequency; for 1kHz you have to type 1000Hz and 1000000Hz for 1MHz.
Ah yeah, sorry, I missed that bit in your original post.
Thanks for still posting that, emrr! Very revealing. Maybe the markings on the Intelligate´s front panel still mean the -3dB point, which differs from the Butterworth implementation? Or are they way off?
Anyway, I´m looking forward to making the changes and listen to the difference, but it could be a while...
I looked at the -3 point relative to panel marking, and it was far off.  In my limited experience this has been true of most continuously variable commercial filters.  The panel markings are rounded "feel-good" numbers.
Hi guys,
ok, so now I have played around with LTSpice a bit and have figured out the component values for the 2nd order HPF mod.
I have attached the plot of the original Autoquad filter (blue), an ideal Butterworth (green) and the modded 2nd order Behringer with around 4dB of gain (red), like abbey road d enver proposed.
I have tested the modded "Behringer with gain" for the whole R range (2k-102k => 30Hz- around 1.5kHz) and the shape stays pretty much the same.
I can´t believe how great LTSpice is!! I just drew the 3 circuits and was able to do comparison plots in no time! (ok, the UI feels a bit clumsy at first, until you get the hang of it). And the best thing is, it gives very similar results to what emrr and I measured in reality.
Anyway, just wanted to share my progress. I will continue to do the 3rd order next, and then start soldering :)
Cheers!
Christian
    60.5 KB
... and the schematic in LTSpice
(PM me if you are interested in the LTSpice file)
    52.3 KB
Ok, I have made some progress here.
I have designed the mod with all the posted ideas in mind, first in LTSpice, and then I modified the actual device.
I modified both one of the 3rd order and one of the 2nd order channels to butterworth response for listening comparisons.
Putting the voltage divider behind the LPF worked like a charm. Having it at the input indeed made the filter curve vary a lot with the position of the pot.
In the following posts I´m attaching the schematic for the 3rd order mod, as well as the measurements comparing the original filter with a 2nd order butterworth, with a 3rd order butterworth. Please note in the schematic that 47909R is the maximum value of the pot 47k + the 909R from the schematic.
The 3rd order butterworth sounds really great, and really different to the original filter.
I´m seriously considering doing the 3rd order mod in all my 24 channels. I´m looking at 200 Euros for parts and probably 1-2 weeks of work.
I have ordered another sample pot that is now 16mm in diameter, but unfortunately a four gang. I´ll see if that fits first, and if yes I can make the decision.
Boy, it would be quite some work though!
Anyway, already the experiment was great fun, and lots to learn here! Thanks again for all your input!!
I was really happy to experience the differences between the filter types first hand in analog.
Great thread!
Christian
    35.9 KB
And the measurements.
Green: original Autoquad filter
Yellow: 2nd order Butterworth mod
Red: 3rd order Butterworth mod
    71.6 KB
