Behringer OT-1 transformer.... anyone know about this thing?
rascalseven
"Tejas"
I've got a couple pulled from some non-functioning DI boxes (DI100, I believe), and they look like miniature, pcb mounted API 2503's (got the copper shield around the middle).
They're about 1" cubed, so not big, but not a dinky modem trafo either.  Look like a 1:1 design with 22ohm and 24ohm DCR on the two windings.  Got a third wire attached at the pinboard as well, but doesn't appear to be connected to any other winding or the core either.... can't get a reading.
Anyway.... if they're useful for something I'd like to put them to use rather than toss them.  Did a google search and really couldn't come up with anything other than dealers charge about $30 for them (probably the most expensive part Behringer sells?)
Anyone built something with them?
JC
You could try a few in the Behr'ger devices that use them as upgrades...that should be good for a laugh or two.
They aren't magnetically shielded, so using them in a DI box on top of a bass amp is problematic.
-a
