Beware of Plastic BM800's
Swift response from Aseyer, I quote:
"The price for Model 18S is 650*2=1300 RMB, which totals 180 USD, excluding shipping fees.
Regarding the purchase of capsules, as their performance depends on the acoustic structure around the capsule and the circuit matching behind it, many fans who bought capsules for assembly found the product failed to meet factory specifications due to a lack of overall planning and design. Therefore, unless it is for mass production or the customer can provide accurate mechanical drawings, we currently do not offer individual capsules"
Nicely worded BS (mostly).
If they do not want their capsules to be bad mouthed by inept DIYers, these are valid points.
Or they do not want to sell small quantities and came up with explanation and conditions. Hard to tell*.
It's like arguing with the "security" buzz word.
Anyway I wrote back with a lenghty but general description of my intentions. We'll see what happens.
May turn out that buying used Tascam/Marantz/ISK would be more economically viable since one gets a good body in the package.
*) My cynical self: "how many mentions (good or bad) of Aseyer capsules, bough individually, you found in the net?"
I agree. It is obvious they do not want to deal with individuals. But, they could have made the point without bad-mouthing DIY enthusiasts. There is no shame in selling exclusively as a wholesale OEM supplier.
Oddly, it reminds me of the time my worker's compensation insurance carrier more than quadrupled my premium, an obvious indication they no longer wanted to service my small company (one part time employee and the CEO/me) even though there was never a claim. Rather than saying it outright, they simply raised it so high I would surely move on ... and I did. (Yeah ... a bit off the trail, but it did remind me of all that.) :)
Later, Gentlemen / James
Many companies fear DIY enthusiasts.
Because we can discover less favorable aspects...
Although they steal from us knowledge, test results, measurements, design ideas and even entire projects. And they make money.
    222.9 KB
    11.3 KB
    469.2 KB
Ah - even smaller.
Tucked into the heads from Teac / Tascam electret mics from the 80s (the cheaper ones with non-removable capsules), but as side-address (posted these long time ago when I had AT capsules in them). Only 2SK660 FET and RF caps inside; used with external electronics. Weigh practically nothing.
I took one of these little Aseyer capsules apart because it's diaphragm was stuck down onto it's backplate - most unusual guts of an SDC capsule I've ever seen (but then I'm sure I haven't seen as many as @kingkorg has!). I'll take some pix and post here and on the Capsule Thread. I still think the diaphragms are (heavily) aluminized polyester. 4 micron aluminum foil would not have survived what I just subjected it to.
    103.6 KB
Capsule worked after reassembly but level was very low and noise much higher; I'm guessing that it got subjected to very strong static electricity zap, and that's what caused the diaphragm to suck down onto the backplate. Possibly this sapped some of the electret charge out of it?
Second photo shows the other sides of the two halves of the backplate. Notice the capsule's center pin doesn't screw into the metal part of the backplate (?). New one on me.
Highly polished side of the backplate that faces the diaphragm almost looks chrome plated. The recessed ring in the middle has a weird, 'molten' appearance.
    272.5 KB
    98.3 KB
    204.3 KB
    177.2 KB
Brass is malleable, ductile, easy to process.
These parts can be moulded, stamped, cold/hot pressed, embossing, machined by chipping, turned, milled, drilled, rectified, polished, etc.
That circular recess is randomly wavy; melted-looking - Never seen anything like that inside a mic capsule.
Apparently Mic Parts used to sell an upgrade kit for this mic, which rather humorously replaces the capsule with the ubiquitous TSB-2555; no way an upgrade in my book!
The Mic Parts circuit may be better, I don't know. They no longer have this kit on their website (but the board is likely the same as many of their other mods for electret mics).
Would have been interesting to hear the original Aseyer capsule with the Mic Parts circuit.
______
Also, just discovered that these little Aseyers fit perfectly inside the empty shell of a Behringer B-5 capsule, but it doesn't leave any of the Behringer shell's threads exposed, so the Aseyer needs to be kept in place with a couple of dabs of Blu-Tack, orthodontic wax, etc.
Seems my hunch about the bum capsule I had having lost a good deal of it's electret charge was correct; inside the B-5 shell, on a B-5 body, where it's recieving full polarization voltage, it's no noisier than an actual B-5 capsule, but sounds nicer to my ears.
I'm liking this combo better than any Takstar mod I've tried.
More convinced than ever that the circuit boards in these Tascam/Marantz/iSK/Stellar Labs mics are their weak point.
Apparently Mic Parts used to sell an upgrade kit for this mic...
I don't believe in conspiracy theories. but something is strange here.
MicParts chose an interesting name for their line of microphones: Roswell.
We've all heard about the recovery of extraterrestrial debris from that 1947 Roswell incident.
That circular piece looks melted !
It doesn't seem like anything ordinary made with Earth technology.
Can we suspect that these are parts of an intergalactic microphone used in a UFO?
Do we have reason to believe it was a DIY alien microphone?
❗Does MicParts use alien technology in its kits?
(sorry, couldn't help myself, my extra-*** humor strikes again!)
I found this too and made me smile. "Upgrade" used to mean chane some parts to make smth better, not replacing everything but the body ;)
There's also a real use review of a TM-80 on MP's site. Not very inspiring nor informative.
Conclusion: an OK mic.
______
Also, just discovered that these little Aseyers fit perfectly inside the empty shell of a Behringer B-5 capsule.
I want to check CM-60/63 as well.
Waiting for parts to finish additional OPIC boards 😉
You mixed manufacturers 😉
It's Aseyer who makes the capsule not MP 😉
So we're talking about a Chinese UFO, not US based 😉
The Takstar bodies are larger diameter than the Behringers.
