Beyerdynsmic Tx info needed
pucho812
third stone from the sun
I searched and search and can’t find data on the following. I couldn’t even find the magic decoder ring.
Tr/bv 372 309 792
It has a date code of 03 84 and has 7 pins in a circular thru-hole solder pin.
Tr/bv 372 309 792
Same doc. as jensenmann.
Just in a PDF format for future ref. in case the link dies.
Page 3 or 4 if I remember well.
M
  • Beyer_Audio_Input_Transformers.pdf
The pdf should get you close enough:
3: means studio grade transformer
72: isn´t in the list: custom mounting
3: two split bifilar primaries, the end of #1 and start of #2 is accessible as center tap
09: 1:9 ratio
The rest of the code isn´t described in the pdf.
