Hello,
I've completed a dual unit of this wonderful DI and it sounds fantastic, have used it on several sources and it just excels , however I have checked some voltages as described on Bo's page :
" Use a digital voltmeter in dc mode and connect the negative test cord to the input jack ground and the positive test cord to the junction av the two 6,8k resistors, or the long leg of the LED if this is used, or the link if the LED not used, and here you should measure +24 volts, +/- 1 volt, if everything works ok.
The next measurment is to check symetrical clipping and headroom.
Move the positive test cord to the junction of 3,9k resistor, 10uF capacitor positive end and emitter on BC560 transistor, and here you should measure around +12 volts, +/- 0,5 volt. "
In checking the phantom power from the console unloaded its about 50vdc , both circuits without an LED I get 25.77vdc at the 6.8k resistors and 12.96vdc at the 3.9k and 10uf junction.
With the LED in circuit I get 27.9vdc and the 6.8k resistors and 11.92vdc at the 3.9k/10uf junction.
EDIT : Phantom voltage when unit is connected to console is 37.74vdc without LED and 38.8vdc with LED
I am using a 3mm red LED with a 780oHm resistor in line for 24vdc operation.
Do these voltages seem correct ?? I mean it works and all , just want it to rock solid
Chip
ps ... Beautiful unit Sandersonic
