Bo Hansen DI layout
Greetings.
I just received my parts from Volker and stuffed them together.
I like to test my units before I plug them onto some expensive gear.
So I looked into Rod Elliott's pages for a makeshift phantom power comprised of my bench supply and two 6.8k resistors. Fig. 3.1 shows quite clearly, how this could be done. The 'scope should see the rest.
The transformer's legs should both be at the same potential, so it should not see any DC.
Do you see any hazard in this approach? Grounding through oscilloscope ground clamp?
It'svery likely this DC woud end up being zero (or very close to it), so the DI would not be powered correctly. Unless your scope is floating...
No risk of fire or nuclear holocaust, but it may not work at all, although non-destructive).
Has your 'scope differential input capability? Where you use one channel as reference, with inverse polarity, and the other as test point.
I would suggest that you test the circuit, which is unbalanced and referenced to ground, and be confident in the good operation of your transformer.
This brought up a good point. No, my scope is not floating. All scopes I encountered so far have their return line tied to earth - for reasons that I don´t understand (but never really researched too).
I always used an isolating transformer to run the scope if that was needed.
But this thing with flipping the polarity. Of course it can do that. Never new what it was good for - now I do!
Must look for a second probe.
But I just realize there is a workable solution. I report back if it works.
Edit: Rod´s circuit referenced above works as a test jig. I tied one capacitor to ground (it can have any potential, as long as the impedance is symmetric) and measured at the second cap.
There is no need to find a place for the scope return, it is internally referenced to the frequency generator.
A 1 Vp-p input yields a 0.2Vp-p output after the transformer.
This is my rendering of the direct input box, FYI. I used a mounting method that I want to share with you.
The PCB fits more or less into a Hammond 1590 N1. I normally use 125B, but those were out of stock and the Hammond is almost exactly the same size.
I say "more or less", because although the PCB is small enough, the jacks are in the way.
I have made a mistake when drilling the holes, so don´t make the same mistake.
Drill the holes for the jacks as far to the rim (upper side when viewing from the bottom) as the connections allow for. This way the PCB can go a little further towards the jacks, and the XLR can be mounted from the inside.
Although this had been my plan in order to be able to mount all connectors from the inside, the jacks got in my way and everything had to move slightly towards the XLR, which had to be mounted from the outside. No big deal.
Note that the jacks may compete with the Molex connectors. I soldered the wires directly.
My preferred mounting is soldering nails, but the spacing of the pads is too small for using them (they shorted on their rims...). There is no real need for using exotic Molex connectors. All the more so, because all other parts are deliberately chosen to be easy to get.
I mounted the PCB onto a helper plastic plate to avoid spoiling the case with ugly mounting screws.
I used 5mm hex metal spacers with an M3 thread, mounted with a recessed screw through the plastic board. The PCB plugs into the protruding screws. The plate can be glued to the bottom with double sided tape, while the PCB can be removed if necessary.
This is quite comfortable and elegant, but raises the PCB somewhat, which fuels the space war again.
So again, it fits "almost". If somebody did their own PCB (I did not care once I realized that it fits a 125B) then this could be made smaller without any problem.
Lacking access to the more streamlined cases I made in the past, I used direct case etching.
This is always a lot of work, and the outcome is not always predictable, but I am satisfied.
Apart from that, etched cases look very professional for a hand-made unit and are (for a generic stomp box) very well readable under subdued lighting conditions. Each specimen thus becomes a peace of art, too. The shiny surface becomes dull from touch quickly, this is normal for aluminium, but it is astonishingly durable otherwise. Please forgive my amateur photography. Them shiny things are very unforgiving.
I ordered the Lundahl transformer, although I probably would not hear a difference to the other ones recommended. It sounds and works flawless upon recording, as expected.
I used the resistor values I could get from my dealer. They had a limited assortment in 0.1% resistors and I had to combine 3 values. The absolute value is irrelevant. I settled for the best match, but the 0.1% were perfectly right from the start.
Thanks Bo for the great work.
Edit: I forgot the input jack grounding when unplugged. Depicted as a red line in the guts shot.
    872.7 KB
    828.4 KB
    937.3 KB
    834.7 KB
    1.4 MB
Hi, congratulations for your work, it looks great and very professional.
Can you please describe the process of etching the case?
How is it done?
Would love to do the same for my DI builds,
thanks, best regards
Certainly.
I whipped together a short write-up on my web site. This is far too long for here (apart from being off topic), it is just a draft, which may get extended.
But after you read about the prerequisites, you very likely don´t want to hear more about the procedure 🤣
Oh and by the way... the design of the above depicted enclosure is a hommage to the original designer. An expression of thankfulness for the huge work he has invested in this, which I am able to acknowledge.
guitar4444,
I have measured many Lundahl transformers but not this particular one, so I don't know how it behaves in my DI-box circuit.
The LL1550 has a large core and can withstand about twice the level in the low register compared to the LL1538, and impedance/ratio configuration "C" according to the datasheet is probably the best option.
If you have access to it, try it, but I think it's unnecessary to buy one to take a chance. The LL1538/LL1538XL is hard to beat in this circuit.
--Bo
Hi Bo, Thanks very much for the reply. I have 4 of the LL1550 that I got many years ago and haven't used, so I think I will try it. I don't have much to compare it to though. Do you think it will handle as much level in the rest of the range?
thx Greg
1000012293.jpg1000012284.jpg1000012291.jpg1000012290.jpg1000012283.jpg1000012289.jpg1000012292.jpg
This was work in progress:
When I ordered the PCB's from Volker, he adviced me to buy the cheapest D.I. I could find.
This one was ideal, because it has all the hardware for re-use, like a groundpoint with screw and XLR PCB. I only needed to cut a bit on both short sides of the PCB, (to make it fit exactly between the metal sides and it already fits snug between the rubber feet) and I had to cut a bit one-side of the XLR PCB.
Not (clear) in the pic's:
- I changed the position of the red wire of the XLR to match the 1,2,3 pin connection on the main PCB.
- I added the missing 3K9 resistor and 2N5088/2N5087 transistor pair.
- I put masking tape under and along the edge of the PCB.
- just in case when one or more of the rubber feet might come of: a little piece of double-sided tape under the transformer side of the PCB, but it was already firm in place.
- I put back the SPDT switches, but haven't used them. Option for a -10dB PAD and/ or switchable impedance like mentioned previous in this thread.
Finally about to build this kit! I've read through threads, looked at old Bill of Material lists (where many components are no longer stocked), searched Mouser for components, read about replacement components etc. But I still need som help with the last steps. I've built stuff previously, but only from kits, so selecting the right components is not that easy when there are so many different ones...
Is there any chance someone would be able to look at my Project Basket and possibly tell me if I've added the wrong components?
Hopefully my list is correct and will help someone in the future too. I've selected Metal film 1% for all Resistors (or would the Carbon Film resistors be better?). Primarily the Vishay CMF Industrial Series, but also RN series in case CMF was not available. I already have Haufe & Lundahl transformes, cases, connectors, PCBs so they are not in the list.
Besides the components list, do most people here solder cables to the connectors (for example XLR) directly on the PCB or do you use some kind of quick connector? Anyone you'd suggest me getting?
Any help and feedback is really appreciated! My goal is to place the order as soon as possible :)
Here's my planned project/order on Mouser with a components list:
https://www.mouser.se/ProjectManager/ProjectDetail.aspx?AccessID=c928d9b103
#QtyTypeSpecificationAdditional InfoMouser LinkManufacturer / Series
12Resistor10 kΩ, 5%, 0.25 W (Carbon Film) or 1%, 0.25 W (Metal Film)Vishay 71-CMF5010K000FHEBVishay / Dale - CMF Industrial Series
21Resistor100 Ω, 5%, 0.25 W (Carbon Film) or 1%, 0.25 W (Metal Film)Vishay 71-CMF50100R00FHEB
Updated after feedback to:
Vishay 71-CMF55100R00FHEK (same 1%, with the higher 0.5W)
32Resistor6.8 kΩ, 1%, 0.25 W (Metal Film)Must be 1% tolerance, Metal Film for precision.Vishay 71-RN60D6801F
Vishay 594-MBB0207VD6801BC1 (improved 0.1% tolerance, higher 600mW, MBB Series)
Vishay / Dale - RN Series
42Resistor1 MΩ, 5%, 0.25 W (Carbon Film) or 1%, 0.25 W (Metal Film)Vishay 71-RN60C-F-1M/RVishay / Dale - CMF Industrial Series
53Resistor100 kΩ, 5%, 0.25 W (Carbon Film) or 1%, 0.25 W (Metal Film)Vishay 71-CMF50100K00FHEBVishay / Dale - CMF Industrial Series
61Resistor3.9 kΩ, 5%, 0.25 W (Carbon Film) or 1%, 0.25 W (Metal Film)Vishay 71-RN60D3901FVishay / Dale - RN Series
72Zener Diode12 V, 500 mW/0.5 WSuggested types: BZX55-C12, BZX79-C12, 1N759, 1N5242Vishay BZX55C12-TAPVishay Semiconductors
82Diode1N4004, 1 A, 400 VAcceptable range: 1N4004 to 1N4007Vishay 1N4004-E3/53Vishay General Semiconductor
91LEDRed, 3 mmOK?VCC 593-LTH3MM12VFR4100VCC
101Electrolytic Capacitor100 µF, Aluminum, minimum rated 35 V, lead pitch 2–3.5 mmTolerance: 5–20%, radial lead. Preferably Panasonic NHG or FC SeriesPanasonic 667-ECA-1VHG101
Panasonic 667-ECA-1JHG101 (higher 63V)
Panasonic - NHG
112Electrolytic Capacitor10 µF, Aluminum, minimum rated 35 V, lead pitch 2–3.5 mmTolerance: 5–20%, radial lead. Preferably Panasonic NHG or FC SeriesPanasonic 667-ECA-1HHG100I
Panasonic 667-ECA-1JHG100I (also changed this one to 63V)
Panasonic - NHG
122Film Capacitor100 nF (0.1 µF), Polyester or Polypropylene, minimum rated 50 V, pitch 5 mmRadial lead, suitable types include WIMA MKS2WIMA 505-MKS2.1/63/5 (63V)WIMA - MKS2
131TransistorBC550C (NPN)According to Bo:
As BC550C use:
512-BC550CBU or 512-BC550CTA
ON Semiconductor 512-BC550CBUOnsemi / Fairchild
141TransistorBC560C (PNP)According to Bo:
As BC560C use:
512-BC557BTA or 512-BC557BTF
ON Semiconductor 512-BC557BTAOnsemi / Fairchild
- I would take some 6k8 resistors with the smallest tolerance possible (0,1% a least) > noise considerations
- The 100uF capacitor should be at least 63V > the supply is +48V
- I'd prefer take a 1/2w 100R for the ground connection
best
best
Thank you for the feedback and suggestions!
I've now updated:
#3: 6k8 resistors: Vishay 594-MBB0207VD6801BC1 (improved 0.1% tolerance, higher 600mW, MBB Series)
#10: 100uF capacitor: Panasonic 667-ECA-1JHG101 (higher 63V)
#11: 10uF capacitor: Panasonic 667-ECA-1JHG100I (also changed this one to 63V)
#2: 100R -> Vishay 71-CMF55100R00FHEK (same 1%, with the higher 0.5W)
Did I understand your suggestions correctly? I've updated my purchase basket on Mouser and the table in the previous post #1410.
Which "quick connector" do you recommend to use? What is the correct name for these white connectors who another user in the thread used?
I'm thinking it would be easier to replace components in the future, but maybe it's better to just solder the cables directly to the PCB. Any tips? :)
Connector ID would be easier if you can post an image looking at one horizontally.
Several manufacturers / types along those lines eg Molex KK ; JST ...
Personally I favour connectors over wires straight into pcb esp for DIY / modification / rehousing etc.
Caveat: with crimp connections it's critical to know how to do it and have adequate tooling.
Also think about screw terminals and "push In" types as available.
