Bo Hansen
Brain,
I never used any simulation software, so I do not know how much it understands of analog design that does not always follow the theoretical rules.
But if you must try to simulate the DI-box, you should remove the two phantom resistors, and instead connect +24 volts directly over 100 uF electrolyte.
You must also connect a 1 kohm termination resistor across the XLR pins 2 and 3 to be equal to the load that the DI-box will see from all phantom resistors and input impedance of pre-amp/mixing console.
You should also measure the output signal over this 1 Kohm resistor.
I do not know if the sowtware can simulate a microphone transformer connected backwards with a ratio of 5:1, which shall then have a primary impedance of 5 Kohms when the secondary side is loaded with approx. 1 Kohms.
And also take into account how the transformer is made, the size of the core etc.
This is a very interesting experiment, and I think there are others here on the forum who understand simulation sowtware much better than me, and have comments on my claims.
Best from
Bo
Best from
Bo
