tagailog said:good day,
I just wanted to ask, how can you connect an external 48V phantom power to this circuit? because my mixer does not have a phantom power so i need to make an external one.
Treb said:tagailog said:good day,
Do not make a 48 volt PSU yourself, buy one on ebay. Search for "cisco 48v psu". Do not pay more than ~15 dollars/euros. These PSUs are generally capable of delivering 350-380mA. More than enough for this DI, as Bo says it only draws ~3.5mA.
I'm not exactly sure where to hookup 48 volts in the circuit so I'll let more knowledgeable people answer that question. You wouldn't want to burn down your house based on my uninformed advice...
Interesting stuff to watch:
https://www.youtube.com/watch?v=6McmnSmiY5o
https://www.youtube.com/watch?v=3w067lYc8Kw
Mondy said:Hi Erazor
Cannot tell if you have added the wire link on the board if you are not using the LED indicator?
Mondy said:Also do you have your 1/4" jacks wired correctly?
Treb said:The input and output jack sockets must be isolated from the metal enclosure for the ground loop suppressor to function properly. Right now you have input and output grounds connected to the enclosure by the looks of it. Use plastic jack sockets to prevent this.
What's the tolerance of those two 6.8K resistors? That gold band usually means 5%, the BOM (and the PCB) specifies 1% for those two resistors.
Treb said:Your image hosting site is being blocked (potential malware etc.). I suggest you first buy the proper plastic mono jacks sockets and hook them up per Bo's instructions. With regard to wiring, try to use different colour wires for ground and signal. Makes troubleshooting off of a picture much easier. How are your soldering skills? What does the solder side of the PCB look like? No solder bridges? Check the resistors, are the correct values in the correct locations? What transistors did you use?
Please DO read the techpage instructions Bo has so excellently compiled, follow those, work methodical and your DI should work flawlessly. Mine and many others' did. Good luck!
Treb said:The noise issues you describe are normal. In an electric guitar (and bass) the strings are connected to ground, usually by a wire connected to the bridge. Just keep a hand on the strings to eliminate the noise.
