Soren,
You can use near all small signal general purpose transistors, that have Vceo 30 volt as minimum, hFE from 200 and up, and fT from 100 mHz and up.
I use BC550-C and BC560-C because this was very easy to get around the world for a couple of years ago, and with right manufactures they was very good genaral purpose low noise audio transistors.
The pc-card are done for transistors that have TO-92 with pin configuration like a old TO-18 in metal can as BC109.
Here are some other transistor types that direct fit on the pc-card. (not need to twist any legs)
BC550=NPN
BC560=PNP
NPN: BC550, BC549, BC546, BC547, BC548, all B or C
PNP: BC560, BC559, BC556, BC557, BC558, all B or C
Here are some older TO-18 transistors in metal can, that also fit direct in the holes.
NPN: BC109, BC108 B or C
PNP: BC179, BC178, BC177 B or C
Then you have hundreds other NPN and PNP transistor, but maybee you must twist the legs to fit in right holes on the pc-card, and you must be 100% sure that you know the transistor pin-out.
Here is some well known NPN and PNP pair that you often can see work together in various audio gear around the years.
As I say before, watch out with pin-out.
NPN: 2SC2240, PNP: 2SA970 GR or BL (the best pair of all transistors)
NPN: 2SC1815, PNP: 2SA1015 GR or BL
NPN: BC184, PNP: BC214 B or C
NPN: BC182, PNP: BC216 B or C
NPN: BC414, PNP: BC416 B or C
NPN: 2N4401, PNP: 2N4403
NPN: 2N4124, PNP: 2N4126
NPN: 2N5210 or 2N5088, PNP: 2N5087
NPN: 2N3707, PNP: 2N3702
NPN: MPSA18, PNP: ------
Of course you can mix all NPN and PNP in a combination.
--Bo
