kante1603
Hello,
I have a strange problem with this remote (as part of a system of FCS920 satellites and a FPS900i Interface).
I wanted to replace the internal battery since the old one was down.Used the same type and connected the remote to the interface as always.Interface indicated charging the remote and everything seemed to be o.k.,but the display now shows only some alternating white lines wtihout even switching it on.Also there´s no function as On/Off anymore.I opened it again.Dc on the battery measured fine,and I found a Reset-button inside.Tried to switch it for long and short periods as well as in combination with the On/off on the front panel.Without any success.
Is anybody here familiar with this system and could perhaps guide me where to look at?
I´m stuck here,the only thing I can say is that it worked before when connected to the interface.
Also tried to put the old battery back in,but no changes at all.
I would really appreciate some help of you guys!
Thank you in advance,
Udo.
Udo.
