[quote author="Flatpicker"][quote author="pstamler"]...I put it back together, started playing, and after about 15 minutes it started crapping out...[/quote]
Maybe heat related? It gets a lot warmer it there when its stuck in the cab, so could be a component going south when it heats up.[/quote]
Uh-huh, my thought too -- but touching the 12AT7 makes the problem go away for a minute or so, after which it comes back.
To Greg: yes, I used a tiny screwdriver to bend the contacts for more pressure on the tube pins. No sign of crud between the pins. And the tube's been in and out of the socket a dozen times already. The preamp tubes, meanwhile, are fine, no problems as far as I can tell.
I wonder whether it's a solder problem after all? Maybe it's time to redo the solder joints anyway, just so's I'll know.
Peace,
Paul
