phatmateo
hmm Im having trouble calibrating the meter as well. I even bought matched fets from hairball. You have matched fets and swapping them enables you to calibrate it?
phatmateo said:hmm Im having trouble calibrating the meter as well. I even bought matched fets from hairball. You have matched fets and swapping them enables you to calibrate it?
spica said:Almost certainly no one has made the same wiring mistake, but has anyone experienced the problem of the Null Adj not doing anything to the voltage across t10 and t11? Any ideas?
Thanks.
spica said:I wish that was the case with mine - this is the second trimmer I've tried and both have tested ok.
ilfungo said:Hi guys
I just finished the calibration of the first blue stripe
everything works fine except the display output to +4
I have about 5 dB difference between the VU meter of the blue stripe and in pro tools
pro tools 0dB
blue stripe-5db
you have any idea about?
thanks
ilfungo said:Ciao Regularjohn
I used the hairball schematics and there are both resistances 3.6ke 8.2K ???
Yes - learn the definition of "Decibel", then find out what 0dB refers to in your Protools setup.ilfungo said:I checked the resistors value and they are correct
I tried to do this mod ( see the picture) and now the 0db in protools is 0db on blue stripe
the only problem I have it's on +8 the difference is 6db instead 4db
Any suggestion?
