Matthew Jacobs said:at the schematic says 1/2 W because that's all that was available back in the day?
muffy1975 said:Can people hear a difference using orange sprague 1uf caps? What is the benefit? Shall I get some? They are not cheap are they!!
phatmateo said:Does anyone know where to find 3707's in the USA with a hfe >=250? Mouser seems to not carry any that do.
emrr said:Matthew Jacobs said:at the schematic says 1/2 W because that's all that was available back in the day?
They are 1/2 W because in manufacturing for the mass market with carbon resistors back then, one would be guaranteed a lower noise floor and fewer complaints by using larger wattage resistors. There's tons of old professional tube gear built with 1W-2W resistors where 1/4 W would be acceptable from a power perspective alone. Much of it still relatively low noise after 50 years. Wouldn't be true to the same degree, if built with 1/4 W. Today, it's not the same issue it once was.
Matthew Jacobs said:So basically we can use 1/4W metal film resistors as they are more reliable, but if using carbon comp it's better to go with 1/2W?
As the Rev A is a special beast, is it best to go with carbon comp to keep that "original sound"?
I found that the 2N5088's were a bit quieter than 2N3707 types and if you get the G version they all have a higher Hfe than 250.I'm going to try using 2n5088's in just the meter section today. I'm using 3708's everywhere else. Does anyone know where to find 3707's in the USA with a hfe >=250? Mouser seems to not carry any that do.
stereokillah said:that's right i 've the version1.1
