sage
I just noticed in the BOM there are 3.6k twice for R18 - it might be a good idea to change it, anyone else noticed?
sage
sage
Have a look at the formula, given at FI http://www.fairchildsemi.com/ds/LM/LM7805.pdf pg.23, fig.12.sage said:I dont have a 1.1k 1Watt but i do have 1k and 1.2k both 1 watt - could i use them instead of the 1.1k ?
If so which one is better 1k or 1.2k ???
sage said:I see that in the BOM for 1.2.5 version there are no Volatges values for the Capacitors axcept for ones in the PS section.
Does that mean that I should get any kind? I am trying to select all Audio Grade Nichicons and Panasonics from Mouser but I sometime there are options 50V or 63V OR....
SUGGESTIONS?
sage
sage said:I have version 1.2.5 R44 shows 5k trimmer and the BOM a 1k var....
is the mistake in the BOM ?
I also pointed out that R18 appears twice in the BOM - could the powers at be perhaps fix these small mistake in the documentation?
MOST IMPORTANTLY FROM WHAT I READ IT IS A 5K TRIMMER FOR R44 - CORRECT?
THANK YOU
sage
sage said:thank you - and for the FILM is WIMA 100Volts good or better Vishay Spraugue 600 Volts?
sorry so many questions... i didn't find a complete Mouser Cart/Bom so I am making my own...
swimslowly said:Does anyone know if these 5002's were wound by Cinemag?
