Echo North
Do you have yellow and orange tied together? I would also check every resistor value and cap in your output amp section.
safe as milk said:hi
thanks for the reply mike..on this unit i have a 5002 with orange/ yellow tied
on the other one i get the same with the cinemag...
i've nearly replaced all the resistors & caps in this section...
if that doesn't get it i'll post up again!
is hfe important at all in the amp section?
cheers
number 2 the docs say-
Insert the appropriate 5 x 20 mm fuse in the fuse holder
- 1/8 Amp Slo-Blo for 120V or 1/16 Amp Slo-Blo for 240V AC line voltage.
safe as milk said:rollocks....my boards are a pair of rev 1
but i also have a new rev2.2 half stuffed
and i did what matahaze did wiring the output trafo to rev2 wiring
as i have covered the pcb writing with screw terminals
finally Q6 gets hot 8)
going to do all sorts of tests now!
safe as milk said:yeah defo my wiring!
in this dual unit i thought it might be a meter switch board so i removed that
and did point to point but no change...
so i swapped the known good main card to the left channel only to get exactly the same error.
this is the box i've been chasing my own tail on for well over a week now...
thats why i put together the 1176 over the weekend to test the cards in which worked well.
cheers
ps i just started reading this thread again from the start & saw my post saying i
bought some trafo's of eanderson in 2006, thanks again....
here i am finally trying to send audio through them 6 years later....
i wonder who holds the record for builds/parts sat on the shelf the longest ;D
sr1200 said:Peter, with your meter in AC mode, check the voltage going into your IEC first. (both sides of the fuse) If your reading is good there, if the reading it good there, remove the transformer from the board and check the leads from the transformer. If you're getting NOTHING from the transformer, i guess it might be possible the transformer blew, but I would have to think that's a rare occurrence (but does happen). If you're getting proper voltage from the tranny, time to check the PS and your VR (and caps... are any of them looking a little bulbous or cracked on top?)
