Hook up a signal to the input, use the signal tracer to see if the signal is present at the input to the pcb (output of the transformer).
If it is, use the signal tracer to see if the signal is present at the input to the output volume pot.
If it is, then the problem is in the output amp.
Check the voltages on the components in the output amp. Check that the components are right. Post more info if you need help. Pictures of your build. Post the schematic with your voltages (listing all the voltages in text may be easier for YOU, but not for the person you are asking to help you).
checking voltages: Q13 seemed off.
Don't worry about the meter driver yet - get the signal preamp and output amp working first.
