HMPS said:this trimmer is definitely bad. i meant 1.99 kohms not hertz my mistake
measuring from center to left it stays 1.99 the other side stays at 2 ohms
doesn't move , i'll pick one up in the morning
Echo North said:You using a slow-blow? It's gotta be a slow blow.
john12ax7 said:Echo North said:You using a slow-blow? It's gotta be a slow blow.
Yes, the 250mA SB blew once, so not sure if it was just a random occorence. Gonna buy some more but right now have a 500mA SB with no issues. But with a 30VA transformer a 250mA seems more appropriate.
Echo North said:john12ax7 said:Echo North said:You using a slow-blow? It's gotta be a slow blow.
If you just blew one 250mA slow blow, that can happen. If you keep blowing them you might have an issue.
Echo North said:Ya for 120V users it's a good common value.
HMPS said:r35 was covered by the other trimmer
r35 -9.6, -0.8
R60 -8 DCV, 0 DCV
R59 -8 DCV other outside terminal 0 DCV
HMPS said:Ok,
We noticed we had 20 and 19 swapped in the wrong slot. Putting them back voltage rail drops down to -8 VDC
When i remove 20 it goes back to -9.6 VDC so there is something on the ratio board that is off?
with 20 wire removed measurements are
r35 -9.6, -0.775
r60 -0.775, 0
r59 -0.775, -0.755, 0
rail 7 -0.45
