You need to take a step back and make sure you are testing it correctly.
The trimmer is a variable resistor, it's resistance is measured in ohms (Ω), not frequency.
Have a look at this image:
Here you see a typical trimmer used as a voltage divider. Out of circuit (not soldered to the board) there is a fixed 10KΩ (yours is a 2K) resistance between the two end terminals. If you measure the resistance (in Ω) between the two end terminals of your trimmer, you'll always get 2K resistance regardless of the middle terminals positions. This middle terminal, called the wiper, is moved by the screw. For your trimmer you need to measure the resistance between the wiper (middle) and either side terminal. If you measure the resistance between the right term and the wiper with the wiper moved all the way right, you'll get near 0Ω. As you move it left it'll increase to 2K. Same with the middle and left term.
Your trimmer is set up similar to the one above except the voltage is negative. Moving the trimmer from the -5 to ground sets trimmer wiper from -5V to 0V.
Now test your trimmer. It may be fine. You may have a different issue, but it's important to test it properly to confirm it's an issue or not.
If you're measuring between the middle terminal and and outside terminal and it's suck at 2KΩ it's broken.
