rokus666
Pad 20 gives me -6.9 V
I don't know what to do anymore as I don't want to keep blowing fuses (running out) ;D
edwardrawls said:Finished my first rev d 1176 today! Worked right outta the gate. Calibrated with no problem.
All of my 3707 measured between 194-210 hfe. I used 5088 in q7-10.
This compressor sounds great!
Thanks to mnats and Hairball.
Ed Rawls
Living Room Recording
Fitting a fuse with the correct value instead might not be the worst idea....rokus666 said:Ok, fuses blowing like crazy.
Hm, I am using 250V 250mAHarpo said:Fitting a fuse with the correct value instead might not be the worst idea....rokus666 said:Ok, fuses blowing like crazy.
Without quoting your mains voltages (why can't people be bothered to put a location in their profile when asking an intercontinental forum) and type and VA-rating of your mains transformer, this number doesn't say that much and BTW is probably missing the fusing characteristic 250mA/x (x might be 'ff','f',' ', 'mt','t').rokus666 said:Hm, I am using 250V 250mAHarpo said:Fitting a fuse with the correct value instead might not be the worst idea....rokus666 said:Ok, fuses blowing like crazy.
I have just blew the last fuse when Gray (pad 21 was connected)
edwardrawls said:my build.
liljeblad said:Hi there folks!
I've just ordered all the components in the BOM except for one that are not available for 16 weeks. This is the component : http://se.mouser.com/Search/ProductDetail.aspx?R=286-240-RCvirtualkey21980000virtualkey286-240-RC
I'm wondering if there is a component that will do the same job or if I'm going to have to wait for 16 weeks before I can start building.
Thank you people!
rokus666 said:liljeblad said:Hi there folks!
Thank you people!
I think this one will work, correct me if I am wrong!
http://www.mouser.com/Search/ProductDetail.aspx?R=CP0005240R0JB14virtualkey61300000virtualkey71-CP5-J-240
maybe add this to your profile.liljeblad said:Since I live in Sweden
Sometimes. AC mains isn't a constant. Will be 230VAC within europe and might vary in range +/-10%, depending on location or time of day.our mains are 240 volts
diameter/length 5x20mm is a common european standard dimension size. (you could still get a hold on ancient 5x25mm sized ones, the 5x22mm from the BOM might be a typo)i need another fuse than the one that's included in the BOM for the rev D. The fuse in the BOM is 5 x 22 mm. The size of the one that I'm looking at right now is 5 x 20 mm.
The datasheet of your fuseholder or fused IEC inlet will know it exactly.Is it of the utmost importance that I find a fuse that has the same size, or i'm I cool?
