Mr_tea said:Sorry about multiple posting but I managed to get signal through however it is at an incredibly small volume compared to the original. Even with both Input and output pots cranked. Is this a sign of a dodgey component? I have measured the voltage at R8 and it is 1.8.The middle Pin of Q2 measures 3.3V. is this a sign that C1 could be broken?
any help appreciated.
Mr_tea said:Is this a sign of a dodgey component? I have measured the voltage at R8 and it is 1.8.The middle Pin of Q2 measures 3.3V. is this a sign that C1 could be broken?
kml23956 said:I have that what I need is the resistor layout on the board. My board has no markings and the doc doesn't help.
Mr_tea said:Ok so after looking at this with a fresh start. I'm checking the voltages against the schematic and I've got the correct voltages up uintill to Q3. The voltage from the Collector side of the transistor should be 12.58V. Instead I have 11.68V. the other voltages on the transistor are ok. Is this a close enough voltage or would I be best to replace the parts completely.
Thanks for everyones help. I'm learning so much by working my way through this.
andydiy said:Someone can help me?
Xicon 286-240-RC , No to cargo storage, Have same value resistors buy ?
In the picture below, Xicon 286-240-RC the location?
andydiy said:The male output XLR, why will be the electricity cable, instead of shielded cable?
