dbonin
This brings up a great point - when testing the ratio/meter board hookup wires for continuity, test from the wire all the way to the pins on the pushbutton pins - this will help ensure you have not lifted a pad on the PCB or caused some other possibly intermittent continuity issue. Just follow the traces from the pads to the pins to make sure every connection is solid.
Trench Recordings said:Hey guys, building my first set of 1176s rev d. Mnats / Hairball.
Looks like I lifted a pad on the ratio board. The green wire, pin 4. Can I solder to the middle pin close to the pad on the 20 ratio switch ? Looks like the trace goes there.
Dave
