Hi andydiy!andydiy said:The Q "Bias Adjustment settings, I can not be mobilized R59, 1176 VU no action.
The trim pot right direction in the picture?
The trim pot we Vishay 2K.
if the 5K have better been ?
I hope you can help me!
Thank you!
Echo North said:number2 said:Q13 is a problem: I read -1.7 VDC on the top pin. (board oriented with mnats logo in bottom left corner)
[these are npn's so I guess that is the emitter because the typical voltage schematic reads -1.63vdc and it's the arrow pointing away?]
I get +11.11 vdc on the center pin. (is that the base?)
and on the bottom pin I get -0.9 vdc (or is this the base b/c the schematic says the base is -1.04 vdc and the collector should be +9.75 vdc?)
I'm also getting the same +11 vdc on both ends of R74 which I was told was no good.
what do I do?
Start by downloading the datasheet for the transistor and confirm the pin configuration:
http://www.centralsemi.com/PDFs/products/2n3707-3711.pdf
Seems like your voltages may be ok. Look at the schematic with V added:
http://mnats.net/files/1176REVD_VOLTS.pdf
See R74? Voltage is simular on both sides. In fact the EBC of Q12 and Q 13 should be similar.
Mike
zekester said:Just figured my issue to be as mentioned earlier in the thread, funky power transformer. It seems to be sensitive to a little movement. I read through and found a few people with issues with these, is there a high failure rate on the avel lindbergs?
Echo North said:zekester said:Just figured my issue to be as mentioned earlier in the thread, funky power transformer. It seems to be sensitive to a little movement. I read through and found a few people with issues with these, is there a high failure rate on the avel lindbergs?
Shouldn't be. Maybe 3% at the most.
zekester said:Echo North said:zekester said:Just figured my issue to be as mentioned earlier in the thread, funky power transformer. It seems to be sensitive to a little movement. I read through and found a few people with issues with these, is there a high failure rate on the avel lindbergs?
I put in an order for a new one, so that should get me back up and running again. Hopefully, I'll be in the 97% on this one![]()
Echo North said:zekester said:Echo North said:zekester said:Just figured my issue to be as mentioned earlier in the thread, funky power transformer. It seems to be sensitive to a little movement. I read through and found a few people with issues with these, is there a high failure rate on the avel lindbergs?
If the new one works fine (confirming the first one you got was bad), let me know and I'll refund your second order.
