TheWolfman
- Joined
- Nov 1, 2011
- Messages
- 69
Curiously on my unit it seems like it adds a little ooomph at around 40hz when compressing which is definetly noticable on a kickdrum for example.Just how I like it! ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
TheWolfman said:I have to say that upon further use of my unit I'm finding it to be rather Noisey.
The noise is based on a 50hz hum,which indicates some kind of grounding issue.I also find the Input pot rather scratchey.
Could this be a ground loop issue?I've connected the balanced input and output leads to each other from the desks insert point and there is no noise,so it isn't a patchbay problem,it is the Rev D itself introducing the noise.It's certainly WAY noiser than any 1176LN I've ever used.
You can see the hum/noise is fairly considerable from the analysis below:
sr1200 said:the pots should be about mid way to make calibration possible(if theyre all maxed or at lowest calibration may not work), but theres no "preset" values.
websoul said:Thanks for your help Mike, I feel a bit red faced now. I had C19 in wrong. Popped it out and turned it around and bingo, back in action.
I can't believe I missed it!!! Two days and it was staring right in front of me, ha!
Thanks for your help though![]()
TheWolfman said:I was just wondering if anyone has experienced that when the output is set to maximum and the input is increased to about 80% or so that the needle maxes out?
This is without any audio passing by the way.Does this suggest that when the output is driven to a certain point feedback enters the circuit?
RichardM said:I tried to calibrate but when I turn up the input during the adjustment the vu meter won't move up to 0 db as it should. I did ground out pad 22 as it stated in the video. Now any suggestions?
Rich
RichardM said:Hi,
The readings were right at the input jack but no luck at the output. I could only get a .07 ac reading there. Suggestions?Thanks!
Rich
