babaorum said:yes all negative values
babaorum said:First problem when I want to do Qbias adjustement. Vu meter doesn't move when I switch bet<ween GR and GR off (lowest in left)
JingleDjango said:Mike, or anyone:
I am following along here and testing my VDC against the PDF linked. Am I right in thinking that the common lead of my meter should be on the power CT, and the red probe will wander to the points indicated by the schematic?
JingleDjango said:Thank you. Moving from top left to top right, everything is normal until I hit Q5.
I'm getting 27.2VDC at the collector, 22VDC at the emitter, 14.2VDC at the base.
(I let the unit warm up for 30 min, meter switch set to GR, no input)
JingleDjango said:CR1 is in right.
C11 is a little blue ceramic cap. I'm having a really hard time reading the value on it.
R29 is correct (I THINK!) Beige 4-band Violet>Red>Green>Gold
R30 I'm not so sure how to identify. When I was stuffing the board I tested each resistor with my meter before placing them and did not rely on the colour codes because frankly they confuse me. The code on this one is: Violet>Green>Blue>Orange>Brown
JingleDjango said:Okay, here's the scoop.
>I'm running the test tone (1kHz) out from Ableton Live through a line out from my Focusrite Saffire Pro 40 at ~0.775VAC (closer to 0.78VAC).
>into the input of my compressor unit
>feeding the output back into the interface. I believe that using a TRS plug like I have into the XLR/1/4" jack will bypass the mic preamp.
I get an audible signal back, which I'm taking as a sign of progress, though this whole endeavour is starting to try my patience! Can't wait to get it working. . .
The signal is very quiet. 0.18-0.20VAC. Despite being this low, the signal also sounds distorted.
I'm keeping the input dial set to 24.
If I turn the output down to 48, the distortion is no longer audible but the signal is so low I have to really drive the gain on the input and turn up my monitors to hear it.
Between 30-24, the signal is distorted but audible, increasing in volume as I turn the dial.
There is an abrupt step up in volume (and distortion) when the dial hits 18.
I don't know if this is relevant, but if I hit the off switch while the tone is going, there is an abrupt jump up in volume before the machine runs out of juice and it fades to silent.
Does this help anyone interpret my signal at all?
JingleDjango said:Thanks. I'm reading up on the colour codes now. It's night-time and I'm using a reading lamp to light my workspace. I guess I've been interpreting the brown bands as violet. These resistors are the correct value.
As best as I can make out, C11 is the correct 10pF (it reads "100")
The issue with the compressor is detailed above:
Thanks again for your guidance.
