Echo North
bxershrts said:Good afternoon Mike and all DIY'ers
I am still scratching my head with this REV D.
checked the GR pcb no shorts(solder connections) all correct resistors.
checked the GR Meter Driver Section - Confirmed each resistor is correct and no shorts.
I am able calibrate the Q Bias
I have swing on the Null adjust and on R71 - But I still +3 volts at the end of the trimmer and the needle at +3VU
Pad 28 and 29 show high volts of +21vdc.
What is the typical volts at pad 28 and 29 with the GR PCB disconnected?
I am trying to find other avenues to look down for build errors based on what I have.
Any hunches or thoughts would be appreciated.
That's pretty normal. They are near the V rail. You can see them noted here on the mnats site.
http://mnats.net/files/1176REVA_125_VOLTAGES.pdf
Can you remind me of your problem symptoms? Considered sending it in for repair?
Mike
