Sounds like a problem wiring the switch on the back of the attack pot. Make sure the wire referred to as #22 is being switched to ground when the switch is in the "off" position.
--Joe
--Joe
mata_haze said:hello,
I have just powered my unit up.
I got the BEAUTIFUL KIT from hairball audio: Trafos, ratio switches Input PAD.
the attack pot is the suggest one from moused with DPDT.
I have wired my unit according to SKYLAR instructions (apart from output trafo which the color coding doesn not match what I have here) and used hairball instructions on how to wire the attack pot up.
i get (even before line up) 46dB of gain before it peaks, i am monitoring using a Neutrik A1 meter (nice piece of kit)
everything seems to be working fine BUT...
I get gain reduction even when the attack pot is on "OFF"
I have checked the usual suspects : wiring, loose connections, dry joints... even if I have left the kattle on....(sorry kinda english humor)
what else am I missing?
any tips will be much appreciated.
Mattia.
