Stagefright13 said:There is no problem with the meter scales. The meter CAN drift up somewhat after extended use as said in the original 1176 manual. That is normal. I calibrate after the unit has been on a few hours. Just follow the video calibration procedures. Then insert R44. then trim the meter as follows:
(This was posted earlier in the thread by another member but explains it better than I can)
So when you're sure about your Qbias, and have then done the Zero meter, 0volts across R74 step....
Here's an outline of my tracking adjust method...maybe it will help:
R44 in
GRmode(20:1)
Your controls set for the 10db swing(10db of GR)
Your source signal coming through...being compressed.
Now, adjust your meter needle to -10VU using the R44 "tracking adjust" trimmer(reflecting the 10db of reduction).
Now, mute your source signal(or short pad 22 to ground), and adjust the needle back up to 0VU using the "0 Set"(R71) trimmer.
Now un-mute your source signal again(or un-short pad 22), and readjust R44 trimmer so the meter needle again shows the 10db of gain reduction(-10VU).
Mute the source signal(or short the 22 pad), and again use the "0 Set"(R71) trimmer to adjust the meter needle back to 0VU.
You should see a slight bit of change(for the better) after each adjustment cycle.
So, repeat this back and forth adjustment procedure until the meter finally holds it's adjustments...
i.e., the meter needle will eventually hold at -10VU when you have the source signal present, and then go back to 0VU when you mute the source signal(or short pad 22 to ground).
Getting to this point usually requires many repetitions of that adjustment cycle.
That's precisely what I did - since the tracking and zero adjust interact so much, I almost used them to achieve the others intent with pretty good results. But it still only reads -6db on the meter. If you switch from 20:1 to 4:1 without touching the other controls should you see more gain reduction at the output?
Thanks for responding SF
