ChrioN
Perhaps a strange question, but: Why did they use odd resistors like 38.3k, 44.2k and 7.68k when the resistors used had a tollerance of 5%? Were these values more common and standardised back in the days?
ChrioN said:Perhaps a strange question, but: Why did they use odd resistors like 38.3k, 44.2k and 7.68k when the resistors used had a tollerance of 5%? Were these values more common and standardised back in the days?
mnats said:ChrioN said:Perhaps a strange question, but: Why did they use odd resistors like 38.3k, 44.2k and 7.68k when the resistors used had a tollerance of 5%? Were these values more common and standardised back in the days?
If you look at the original schematic you'll see that they didn't use these values as they weren't at all common.
ChrioN said:you're rightthats quite embarrassing. How come you didn't use the values from the rev A schematic?
DrFrankencopter said:R44 is disconnected.
Biasrocks said:DrFrankencopter said:R44 is disconnected.
Are you putting the meter at 0VU before you adjust meter NULL?
Mark
DrFrankencopter said:Yup... I used R71 (front panel adjust) to get the VU to read 0 in GR mode. Bringing this pot CCW raises the needle position on the VU....but every time I adjust R75 from there the VU needle keeps falling, and I need to keep turning R71 CCW to bring it back up. Eventually I get R71 all the way to the CCW stop, and I still can't null R74.
On your build, when you turn the front panel pot CCW, which way does the VU meter needle move?
Kris
DrFrankencopter said:Also, is there a schematic for Mnats 1176D?
kilmister said:DrFrankencopter said:Also, is there a schematic for Mnats 1176D?
Yes there is: http://mnats.net/1176_revision_d.html
-Paavo
