Wiring for the Altran on the Rev D version 2. Mine is a mono unit.benlindell said:I have a question regarding using the old h-pad boards, I found the talking about it on about page 15 but all the links and images are dead, anyone have some info on how to hook these up?
benlindell said:Ok, but if I want to use a tpad attenuator I just hook it up like canidoit's pictures correct?
ChrioN said:For those of you who got the VU meters from hairball, with the 12v 1.2w lamp: from where did you get the juice for the lamp?
benlindell said:mnats, would you happen to still have the photos around that accompany this post: http://www.groupdiy.com/index.php?topic=20058.msg246397;topicseen#msg246397
benlindell said:I believe I have some of these boards.
benlindell said:I set the q bias just fine but when listening to it as soon a signal hits the threshold it goes crazy with the gain reduction, any ideas what may be causing this? I have 2n5088s in q7-q10 and 3707s in q5, q12, q13, could that cause this?
Signal | C17 | C19 | C20 | Pad 19 | R55/6 | Q1 |
AC | AC | AC | DC | DC | AC | |
-3dB | 0.8V | 0.4V | 1.0V | -0.568 | -0.568 | 0.08 |
0 dB | 1.0V | 0.7V | 2.0V | -0.539 | -0.568 | 0.10 |
+3 dB | 1.2V | 1.0V | 2.5V | -0.464 | -0.568 | 0.12 |
