college101
got it working..the new fuse I put in was bad! its working now!
The first and most obvious is the C pin on Q3 is only reading 5V but it should be 12V according to the schematic. Same with Q14 pin E
Following the schematic: 30V -> R17(6.8k) -> R14(22k) -> Q3 pin C (12.58V)
I tested R17 and R14 and they are the correct values but testing each side of the resistors along the way I get this
30V -> 30V[R17]23.85V -> 23.85V[R14]5V -> 5V [Q3 pin C]
It would seem something is going wrong at R14 but it reads 22K exactly as it should.
Can someone help me solve this mystery? My electronics knowledge is fairly limited.
Here are some other Readings
SCHEMATIC MY UNIT
C B E C B E
Q2 1.75 1.05 0.54 1.5 0.71 0.21
Q3 12.58 -- 1.15 5.0 1.5 0.85
Q14 -- -- 12.0 30.0 5.0 4.39
And I'm getting exactly 30V and -10V at the test points in the power supply section.
TijuanaKez said:Which part? The only suspect part was the 2n3391 at Q14 but I tried a fresh one and still the same.
college101 said:OK..so R44 still does not work...Inserted it in place, re solder'd and nothing...Once I go into GR mode from the VU or +4 setting back into GR mode...U re zero the meter using R71...then turn on the compression, and watch the needle drop to the LEFT from the zero...mine lands around -7 and no amount of turning r44 moves the needle to -10...HELP
I am also noticing a lot of Drifting by the needle....Does anybody else have a lot of movement in their VU meters needle movement?
Comments please...I am going on my third R44 2k trimmer...and now I have to order some more to change it again
Ive seen a few posts from other people where they were using the big pots with wire leads coming from their mnats boards to the pots, they replaced them with the small mini trimmers...Is this my next move to set r44 correctly? Speak up fellow 76'ers~!!!????
hi i recently purchased a 1176ln hairball rev d kit with mnats board v2.2.
(input transformer: altran C3837-1, output transformer: 5002)
and got it totally assembled and wired, now i got following problems:
0,770V sinus 1khz on input
output measurements (input pot and output pot fully CW) - 0,3V on blue(pin2) 0V on
red(pin3)
as you see i dont get proper levels (sound is also very very thin and
> output unbalanced)
> further measurements with Scope:
> wave shows only before input transformer and on GREY output from board
> no wave behind input transformer (board sockets) no wave on Q2-Q6.
> DC measurements show correct values refering to mnats shematic with typical voltages.
> also resistors should be ok..
> Hopefully some has got an idee what could be wrong.
Thanks for any help!!
