Yes ignore. Same goes for the 2 related R's. I have them listed in the BOM as such.NoahShain said:I've noticed there's a spot on the main pcb for hi-z/low-z jumpers but none are included in my kit or in the assembly aid.
Ignore?
Thanks for the reply Jeff. I bought an extension jig but I botched the build! I broke the ribbon cable connectors trying to clamp down on the ribbon cable. I was gonna order a new one last night but the store was closed so I just made everything.jsteiger said:Hi Noah, sorry you are having trouble. If you are using my Extension Jig, you do not need a "special cable". The Extension Jig takes care of that. All you need to do is engage the pushbutton switch during CMRR adjustment. The instructions printed on the silkscreen of the Extension Jig PCB should get you there. If you are using the jig AND a special cable, that could be your trouble?
Yep! The cable is measuring correctly. Got 1v at the output.jsteiger said:You should be able to measure with your DMM at the output end of the special cable to make sure it is functioning properly. I mention this in the doc about building the cable. You should be able to adjust the output of your sig generator to give you appx 1V AC at both pins 2 and 3 of the output XLR.
Andy, resistors cannot be accurately measured when they are soldered in circuit. The results will vary. If you are really questioning their values, either use the color codes or one end must be desoldered and lifted from the PCB before measuring.andycallison said:so i have tested all the resisters that are on the pcb.. there seem to be a few issues
R2 should be 130k and its 11.75K
R3 should be 13k and it's 11.75K
R10 should be 14.3K and it's 4.1K
R14 should be 10K and it's 4.83K
R15 should be 10K and it's 4.11L
R20 should be 2M2 and it's 5.92K
R26 should be 220K and it's 199R
i also did the test points...
1. 5.7Mv
2. 5.6Mv
3. 53.5Mv
4. 2.6Mv
5. 56Mv
6. .6Mv
7. .2Mv
so none of those seem to match either!! any advice would be greatly appreciated
cheers
Andy
Wrong thread.....NoahShain said:Just finished my first LC53 build.
Not passing signal at all...just a buzz. Like a nice loud 60 cycle hum.
Any tips where to start diagnosis? My instinct says the little op amps or followers...they're tough!
Thanks all
