Marshall Pilot / Indicator Light... DIY?
Che_Guitarra
Australia
I've got a Marshall 2266 Vintage Modern with a blown pilot / indicator light (LED).
Where I can find replacements, shipping costs to Australia are exorbitant (the most I saw was $175... to get an LED to my door... you have to be kidding me!!!).
I'm wondering if I could just DIY a fix. The component in totality is below. Not much to it.
Surely, with a bit of patience to disassemble, I could just replace the blown LED itself?
Could you wire up another LED with dropping resistor, drill a hole, and glue that one in? I'm guessing the plastic would distribute the light enough for it to look decent. Maybe a high brightness one?
Looking at it more closely, it looks like the white bit is a separate assembly and has a "key" (if you will) that fits into the square hole on the top of the barrel. It might be an easy pull if not glued in place.
