Yes. I have been crazy slammed here.Homestudio said:Hey Jeff, did you see the email I sent?
From the manual of your DMM:Jeremiah Blair said:The voltage at Op Amp +V and -V look okay, not perfect, but I believe they're close enough.
Voltage at TP 9 and MTR Board #11 are spot on. Data at TP1, TP2 and TP3 are significantly off target. What may be wrong or what do I need to investigate?
Note I'm using my DAW to send 24.5mV AC to the unit at 1,000 Hz and using my Extech EX350 DMM for measurements. Using SL-Red Dot Op Amp.
Resistance to -V on DOA socket 3.32 kΩ
Voltage at +V on DOA socket: +15.02 DCV
Voltage at -V on DOA socket: -14.83 DCV
TP9 is -10.01V DC
Meter pt. #11 is 2.501V DC
TP1 is 14.79mV AC (target value = 5.8mV AC)
TP2 is 789mV AC (target value = 117.7mV AC)
TP3 is 4.66V AC (target value = 939mV AC)
Module's Output is 2.511V AC as measured at card edge terminal 4: "Output - " (target value = 1.89V AC)
Module's Output is 2.537V AC measured at pins 1 and 3 of male end of output cable (target value = 1.89V AC)
Jeremiah
jsteiger said:From the manual of your DMM:
(ACV frequency response is 45~400Hz)
That said I would use 100Hz or 200Hz or something as the test tone and not 1kHz.
Jeremiah Blair said:I decided to look for bad solder joints, and ultimately decided simply to re-flow all of them, but no significant change:
TP1 = 14.1mV AC
TP2 = 710mV AC
TP3 = 4.12V AC
Output = 2.21V AC
Yeah, looks like something is not right with one of them. You will have to visually compare the 2 units and see where you made the error.dansvillalba said:Hi! Jeff
A Few days ago I finished to build and calibrated my two FC526 compressors.
Making frequency response test in both compressors , I noticed that one of them had a roll of in high frequencies.
Why is this happening? Did I make anything wrong? :-\
