santiagoclement
Member
- Joined
- Apr 8, 2019
- Messages
- 6
Hi Jeff,
I did apply 1kHz sine wave -30dBu with the fc526 bypass, but i received -60dBu on the output level. (It seems there is something wrong with the bypass), as it does not let out what goes in) When I flip the Bypass toggle to ACT, I have on the output monitor -22.6dBu, what it is only +8.6dBu. (I did as you said, I monitor the output of the fc526 going back into the DAW)
There is something else. Before I jumped RV7 (I forgot to do it so), I had 2.498V DC on point #11, but after ding the jumping in RV7, and power in up the module, I find to have 2.616 V on point #11.
Do you know what could be the issue? I also have since the first time I powered it up, all the LED illuminated except the last "20" red LED.
Thabk you.
Regards,
Santiago
Thabk you.
Regards,
Santiago
