You should be fine at -26dBu. Just keep in mind that all levels stated will be 4dB hotter. This is only during the first few steps (VVR adjustment & audio path dbl check). I chose -30 because one can safely run both pots wide open and not worry about anything clipping.steveau said:Jeff,
I'm having problems with the calibration section.
My signal generator only goes down to 0.1 volt, so I don't think it can generate anything less than -26dBu,
I tried to use a computer generated signal, but my fluke DMM readings are jumping around and I don't know if I can trust it.
Sorry to be so technically challenged, is there a louder level that could be used to calibrate?
-Steven
So you get appx 24mV AC at TP1 with 24mV AC signal at the input? Try different opamps in the receiver spot. If it persists, post a pic of the group of R's between the receiver amp and the output transformer.tctonn said:Jeff, et al
Howdy. I am having some issues with calibration on both of my units. When I feed aprox -30dB (-.024v) in to test the audio path I am getting the same voltage reading at TP1. At TP3 I have 2.898v.
I have a 1731 in the receiver slot and red dots in the other two opamp slots. All three opamps work well in my VP28.
jsteiger said:So you get appx 24mV AC at TP1 with 24mV AC signal at the input? Try different opamps in the receiver spot. If it persists, post a pic of the group of R's between the receiver amp and the output transformer.tctonn said:Jeff, et al
Yes they are and I use the same alternating method for them.Unit7 said:Jeff, I remember reading somewhere that when soldering a couple of transistors you switch between them to not overheat. This is the first time I'll solder ICs directly to the PCB. Are those sensitive to heat too? Make sense using the same method?
This part of the build is a little odd and hard to describe. RV8 does not work backwards but the entire procedure is conceptually "backwards". If you are getting farther away, then turn RB8 in the opposite direction.Unit7 said:I noticed that the action of RV8 isn't 'backwards' as described, resulting in (I believe) that when toggling GR on/off and trimming RV1 and RV8 accordingly, the measurements gets more and more off. Anything obvious comes to mind?
Unit7 said:when toggling GR on/off and trimming RV1 and RV8 accordingly, the measurements gets more and more off.
jsteiger said:This part of the build is a little odd and hard to describe. RV8 does not work backwards but the entire procedure is conceptually "backwards". If you are getting farther away, then turn RB8 in the opposite direction.Unit7 said:I noticed that the action of RV8 isn't 'backwards' as described, resulting in (I believe) that when toggling GR on/off and trimming RV1 and RV8 accordingly, the measurements gets more and more off. Anything obvious comes to mind?
Exactly what I did at first. But you shall not aim for the listed voltage when trimming the RV8 (GR on), instead trim further away. Then, because of the interaction trimming the RV1, with every step you'll get closer instead of the opposite.emrr said:the turning was specific to the correct direction to hit the voltage listed for the step at hand.
I think that is a little funky. There should be plenty of room on both trimmers to cal the meter in perfectly.Unit7 said:I did that and was able to get one unit perfect and the other almost, because the RV8 hit the bottom and I settled for 2.489V with GR off and 2.235V with GR on. The meter behaves, but Jeff would you say that is close enough, or is there something funky about the RV8 hitting the bottom?
Thanks Jeff! Played with them for a while (GOOD SH*T MAN!!!) and they seem to sound/behave very similarly, so I'll probably have to get back to this more later. But now, while at it, any suggestion on where to start looking except go over all solder points?jsteiger said:I think that is a little funky. There should be plenty of room on both trimmers to cal the meter in perfectly.Unit7 said:I did that and was able to get one unit perfect and the other almost, because the RV8 hit the bottom and I settled for 2.489V with GR off and 2.235V with GR on. The meter behaves, but Jeff would you say that is close enough, or is there something funky about the RV8 hitting the bottom?
